Glen,
Have a look at an article I wrote about scaling the analogue out. In that article it really just discusses how to alter voltage levels to a format that one may need for driving an external system (such as a DC servo amplifier). However, the technique isn't just limited to voltage, the output stage is capable of upping the current flow too, it's just a case of looking more at the OPAMP buffer as a current amplifier instead. When thinking in this way you really should be looking at articles like Wikipedia's Current Source to understand more about the subject.
The main problem you have is what can an Mbed (LPC1768) pin source or sink? And, as a device, what can all the pins source or sink as a whole. One method to increase the current through an LED via a digital out pin is to tie the LED anode to VCC and the cathode, via a resistor to the Mbed pin. The value of the resistor should be choosen to limit the current to the maximum of a single pin (which should be configured to sink current, not drive current). Then, if you tie two digital output pins together, you can alter the resistor to double the current (or use two resistors, one to each pin, thus connecting them in parallel which has the same effect as lowering the value of a single resistor). However, you cannot keep doing this, adding more and more pins as the chip itself will have a maximum sink current "overall" which you don't want to exceed without breaking it.
When it comes to joining two analogue pins together, well, without some sort of buffering all bets are off. No two analogue outputs are ever going to be identical and you may end up with a push/pull current flow between the pins, not so good. So in that case, I would just use a single output buffered with an Opamp that can deliver the current needed to drive the external circuit/LED.
But it seems you may need to get yourself an electronics catalogue for mail order components because it sounds like you may need some extra "ummmph"  to get those LEDs doing what you want ;)
Hey guys, been ahwile. quick question, My analog out seems to be off... A value of 0.0 gives maybe 1.6-2.0 Volts tops (no meter with me) but it seems to be inverted... and the highest i can get to is about .30 and then voltage dies off completely. Any ideas?
p.s. i have some garbled files on my Mbed drive (one claims to be 3.82 GB)
(kinda a last minute haloween costume idea, haste would help :)
