cubemx and mbed configuration
02 Jan 2017
Hi everyone,
I am trying to configure my nucleo F767 board with cubemx. I tried the LED flashing code using HAL library and it was successful. I used keil v5 to export from cubemx then I added the necessary files to online compiler. Here is the code and file list that I insert from cubemx.
Blinky with HAL
#include "main.h"
#include "stm32f7xx_hal.h"
void SystemClock_Config(void);
void Error_Handler(void);
static void MX_GPIO_Init(void);
//DigitalOut led1(LED1);
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
      HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_0);
      HAL_Delay(500);
       // led1 = !led1;
       // wait(1);
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
    /**Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  /*Configure GPIO pin : PC13 */
  GPIO_InitStruct.Pin = GPIO_PIN_13;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  /*Configure GPIO pin : PB0 */
  GPIO_InitStruct.Pin = GPIO_PIN_0;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0, GPIO_PIN_RESET);
  /* USER CODE BEGIN Error_Handler */
  /* User can add his own implementation to report the HAL error return state */
  while(1)
  /* USER CODE END Error_Handler */
here is the list that I added from keil v5 project. /media/uploads/randalthor/cubemx_mbed_dosya_aktar-m-.png
After it was done successfully, I decided to read the encoder and see the value on the computer with Serialpc. The code was compiled without errors but I could not read the values through the serial port. When I deleted the clock settings which is created by cubemx, SerialPC works fine, but the code does not enter the timer because timer value does not change. Here is the code that I used.
Encoder with HAL and mbed
#include "main.h"
TIM_HandleTypeDef htim1;
Serial pc(SERIAL_TX, SERIAL_RX);
static void MX_TIM1_Init(void);
uint16_t count=0;
    HAL_TIM_Encoder_Start(&htim1, TIM_CHANNEL_ALL);
    HAL_Init();
    MX_GPIO_Init();
    MX_TIM1_Init();
        count=TIM1->CNT;
         HAL_Delay(100);
        pc.printf("Encoder value is %d\r\n", count);
    Error_Handler();
    Error_Handler();
  TIM_Encoder_InitTypeDef sConfig;
  TIM_MasterConfigTypeDef sMasterConfig;
  htim1.Instance = TIM1;
  htim1.Init.Prescaler = 0;
  htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim1.Init.Period = 65535;
  htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim1.Init.RepetitionCounter = 0;
  sConfig.EncoderMode = TIM_ENCODERMODE_TI12;
  sConfig.IC1Polarity = TIM_ICPOLARITY_RISING;
  sConfig.IC1Selection = TIM_ICSELECTION_DIRECTTI;
  sConfig.IC1Prescaler = TIM_ICPSC_DIV1;
  sConfig.IC1Filter = 0;
  sConfig.IC2Polarity = TIM_ICPOLARITY_RISING;
  sConfig.IC2Selection = TIM_ICSELECTION_DIRECTTI;
  sConfig.IC2Prescaler = TIM_ICPSC_DIV1;
  sConfig.IC2Filter = 0;
  if (HAL_TIM_Encoder_Init(&htim1, &sConfig) != HAL_OK)
    Error_Handler();
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  sMasterConfig.MasterOutputTrigger2 = TIM_TRGO2_RESET;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
    Error_Handler();
  __HAL_RCC_GPIOE_CLK_ENABLE();
  while(1)
Where do you think I made a mistake?
28 Jan 2017
Here is the two things that I have learn.
1) Nucleo F767ZI already running at 216Mhz with mbed os. Does not need to speed it up by adding system clock configurations from cubemx.
2) Always pullup your encoders! Now it works.
23 Mar 2017
Could you please tell me what you did to get it to work. Did you delete SystemClock_Config completely or just certain parts of it. I am trying to get some PWM DMA code to work but when I start a HAL_TIM_PWM_Start_DMA my code seems to hang.
01 May 2017
David Fisher wrote:
Could you please tell me what you did to get it to work. Did you delete SystemClock_Config completely or just certain parts of it? I am trying to get some PWM DMA code to work but when I start an HAL_TIM_PWM_Start_DMA my code seems to hang.
Yes, I have deleted SystemClock_Config function. I am using PWM with HAL_TIM_PWM_Start and it works fine. Also, I use ADC DMA with HAL_ADC_Start_DMA function. I do not have any problem with those.
03 Jan 2018
where is this configured in mbed's code? I might need to change it someday, or is there a good reason not to? I'm now having the problem of not getting the functions of stm32l4xx_hal_msp.c replace the weak function of stm32l4xx_hal_adc.c
Do you know if there is an extra step?
09 Jul 2018
Hi all I am using the same board and I kept getting "XXX_HAL symbol multiply defined" error message... Can anyone help?
Thanks!
