ADC Value
23 Aug 2010
Dear forum,
I try to read 3.3V regulated power source by the AnalogIn (p19). I use example code (in handbook) which is reading ADC to a unsigned short variable in 1024 times. I want to read an ultrasonic sensor, so I need more accurate reading rather than the normalized floating point (0.0 - 1.0). Consider that the analog source is constant in this case is 3.3V (regulated), but the value is like this:
1007, 0xFFFF, 65535
1008, 0xF0FF, 61695
1009, 0xF2DF, 62175
1010, 0xF4AF, 62639
1011, 0xFFFF, 65535
1012, 0xFFFF, 65535
1013, 0xFFFF, 65535
1014, 0xF23F, 62015
1015, 0xF44F, 62543
1016, 0xFFFF, 65535
Could anyone explain why? Then, how many byte is this mbed ADC resolution? It is just form 0.0 to 1.0?
I also try another voltage value and it results something similar.
Thank you
/rhj
23 Aug 2010
And... how to reduce the noise?
23 Aug 2010
Which model range finder are you using?  I just finished programming a max botix mb1210, maybe the class is useful to you?
MB1210
What resolution do you need?  From my experience, the only way to reduce noise is increase voltage on the device (if that increases the wave intensity), but that is dependent on the device and may require you to scale the output voltage back down to the mbed's pins.
For accuracy, I wouldn't recommend Analog.  Is Serial or PWM available?
I hope that helps
Thomas
23 Aug 2010
The ADCs on the LPC1768 is 12 bit (10 bits on the LPC2368). The unsigned short read method of the AnalogIn class normalises this to 16 bits.
23 Aug 2010
Thanks Thomas and Jon for your info, it really helps. My Senscom mini-A ultrasonic sensor has PWM output and yes, using PWM is the better way in this case.
cheers,
/rhj
