Yes, ADC seems to have low impedance input - for audio I'm currently driving it from a headphone out, an audio line out doesn't work great at all. Also using a resistor divide for dc bias and a capacitor to couple the ac circuits.
From resetting mbed the results take a good while to settle. I'm looking at adding an active buffer.
Would be useful if the mbed guys to recommend a suitable front end. The 1768 application notes and schematics are patchy, and there's also additional circuitry on the mbed board (LC circuit on the ADV supply voltage and positive ref for instance).
The ADC supply is tied to the ADC +ve ref on the schematic - so I guess if you're pulling enough power for the Vu voltage to drop at all, the ADC results will indeed vary.
I have noticed some unexpected behaviour of the ADC cicuits.
A bit of investigation shows that the measured voltage, with constant input voltgae, appears to depend on the total "load" on the Vu line. The main load is an LCD display which draws 18mA (measured).
I am powering my mbed from the USB line.
Am I overloading the power line or is soemthing more subtle happening?
