I'm trying to log AD345 data via SPI on InterruptIn and write it to an open local file with fwrite() in binary directly from the interrupt routine. I find that my ideal data rates are right on the margin for the flash memory. It is almost OK at 192 bytes per 20mSec (800s/s) but quite marginal at 192 bytes/10mSec. (the fifo on the AD345 gives a bit of leeway). Average measured single buffer dump seems to be about 15mSec but some are a lot longer (in some areas of the flash, changing block, cell errors?). It's the long fwrites() that are the real problem - occasionally >50mSec or more.
What is the fwrite() buffer size? Can it be changed?
The fwrite() appears to mask InteruptIn, does it? Also does pc.printf() mask it?
When using InterruptIn I can't get wait() to flash my led - low interrupt priority?
Chould I expect faster write speeds with a SD card FAT file system, or do I need to go to a raw storeage?
- Given that fwrite() masks the interrupt, I don't gain by fwriting as a forground task because I loose control of the relative timing. Any suggestions?
