Sorry james...  I had an include for data.h in there I guess I missed it...
 This could be refined...alot probably.. but I hope it helps..
 main.cpp
#include "gps.h"
#include "data.h"
        getGPSstring(1);    // The one denotes the mode
 data.h
#ifndef _DATA_H_
#define _DATA_H_
    char gpsString[1024];
    char gsv1[1024];
    char * gsv2;
    char rmc1[1024];
    char * rmc2;
    char gga1[1024];
    char * gga2;
    char * fix;
    int sep;
    int mode = 1;
#endif
 gps.h
#include "TextLCD.h"
#include "data.h"
// Green wire to pin13
// White wire to pin14
DigitalOut led1(LED1);
DigitalOut led2(LED2);
DigitalOut led3(LED3);
DigitalOut led4(LED4);
Serial pc(USBTX, USBRX);
Serial gps(p13, p14);
TextLCD lcd(p21, p22, p23, p24, p25, p27, p28);
int parseGSV() {
                    gsv2 = strtok(gsv1, ",");
                    while (gsv2 != NULL) {
                        sep++;
                        switch (sep) {
                            case 1:
                                // # of sentences
                                lcd.printf("#:%s\n",gsv2);
                            break;
                            case 2 :
                                // Sentence # of #
                                lcd.printf("S#:%s",gsv2);
                            break;
                            case 3 :
                                // Number of Satellites in view (Should give a hint as to how many cases to expect here...
                            break;
                            case 4 :
                                // Satellite PRN Number
                                lcd.printf("PRN#:%s\n",gsv2);
                            break;
                            case 5 :
                                // Elevation in Degrees
                            break;
                            case 6:
                                // Azimuth in Degrees
                            break;
                            case 7:
                                // SNR - up to 4 satellites per sentence
                            break;
                        gsv2 = strtok(NULL, ",");
                    sep = 0;
    return *gsv2;
int parseRMC() {
    return 0;
int parseGGA() {
                    gga2 = strtok(gga1, ",");
                    while (gga2 != NULL) {
                        sep++;
                        switch (sep) {
                            case 1:
                                if (mode == 1) {
                                    lcd.cls();
                                    lcd.printf("Time:%s\n",gga2);
                            break;
                            case 2 :
                                if (mode == 2) {
                                    lcd.cls();
                                    lcd.printf("Lat:%s",gga2);
                            break;
                            case 3 :
                                if (mode == 2) {
                                    lcd.printf("%s\n",gga2);
                                    wait(0.25);
                            break;
                            case 4 :
                                if (mode == 2) {
                                    lcd.cls();
                                    lcd.printf("Lon:%s",gga2);
                            break;
                            case 5 :
                                if (mode == 2) {
                                    wait(0.25);
                            break;
                            case 6:
                                if (mode == 1) {
                                    if (gga2 == "0") {
                                        fix = "Invalid";
                                    if (gga2 == "1") {
                                        fix = "GPS Fix (SPS)";
                                    if (gga2 == "2") {
                                        fix = "DGPS Fix";
                                    if (gga2 == "3") {
                                        fix = "PPS Fix";
                                    if (gga2 == "4") {
                                        fix = "Real Time Kinematic";
                                    if (gga2 == "5") {
                                        fix = "Float RTK";
                                    if (gga2 == "6") {
                                        fix = "Estimated (Dead Reckoning)";
                                    if (gga2 == "7") {
                                        fix = "Manual Input Mode";
                                    if (gga2 == "8") {
                                        fix = "Simulation Mode";
                                    lcd.printf("FIX: %s_%s",gga2,fix);
                            break;
                        gga2 = strtok(NULL, ",");
                    sep = 0;
    return *gga2;
int getGPSstring(int str) {
    if (gps.scanf("%s", &gpsString) ==1) {
        if (str == 1) {
            if (sscanf(gpsString, "$GPGSV,%s",gsv1) >= 1) {
                sep = 0;
                parseGSV();
        return *gsv2;
        if (str == 2) {
            if (sscanf(gpsString, "$GPRMC,%s",rmc1) >= 1) {
                sep = 0;
                parseRMC();
        return *rmc2;
        if (str == 3) {
            if (sscanf(gpsString, "$GPGGA,%s",gga1) >=1) {
                sep = 0;
                parseGGA();
        return *gga2;
    return 0;
I have a Skytraq Venus 6 GPS that outputs the full NMEA serial string connected to my mbed. Does anyone have a NMEA parser code already ported to the mbed? I need to pull data from several string formats as you can not get position, altitude, speed, and heading from one single format.
The Search comes up empty.
