Hi Martin, Dan,
 Remember ~ means "invert", and not "not", hence ~(Status & 0x46) will always be true (as there will always be some bits 0 before inversion).
 Changing ~ to ! should make this work. i.e it is only true if all bits are 0.
 However, another approachof constructiong your logic may be more readable. If you think about it, you are checking some bits for a fixed value, and ignoring others. Therefore, a natural construct might mask the ignored bits to 0, then compare to the desired result with 0's in don't care positions:
 if((VALUE & MASK) == DESIRED)
 so in your case:
 if((Status & 0xC6) == 0x80)
 Appologies in advance if I slipped up, but you get the idea.
Hi all,
Hoping someone can help me here. I have a program with a byte made up of 8 status flags. I want to run a piece of code only if bit 7 is high AND bits 6, 2 & 1 are all low. So far I have ...
if((Status&0x80)&&(~(Status|0x46))){ Run code here}
This doesn't work how I thought it would, can someone put me out of my misery?
Martin
