Hello there, anyone had succedeed in changing the color of this RGB module? I am trying to port the arduino code to the mbed code.
![Blinkm Module](http://thingm.com/fileadmin/thingm/images/photos/tm_blinkm_closeup_obliq_sma.jpg)
Here you are the arduino code
Wire.begin(); // set up I2C
Wire.beginTransmission(0x09);// join I2C, talk to BlinkM 0x09
Wire.send(‘c’); // ‘c’ == fade to color
Wire.send(0xff); // value for red channel
Wire.send(0xc4); // value for blue channel
Wire.send(0x30); // value for green channel
Wire.endTransmission(); // leave I2C bus
And this is my translation of the code ported to mbed
I2C i2c (p28,p27); // Setup the I2C interface: sda, scl
i2c.write(0x09, "c", 1); // Send command string
i2c.write(0x09, "0xff", 1); // Send command string
i2c.write(0x09, "0xc4", 1); // Send command string
i2c.write(0x09, "0x30", 1); // Send command string
Link to the compiler code: BlinkM
The only problem is: it does not work... Can someone help me please?
Note: 0x09 is the factory address of this I2C module
Please find below the datasheet of this module including arduino samples
http://thingm.com/fileadmin/thingm/downloads/BlinkM_datasheet.pdf
