Hi Andrew,
Sorry to hear about this issue. I have a small hunch about this, that I'd like to examine. I would like to try and ascertain whether or not this has something to do with the behaviour of the modem itself.
Can you tryout this program please:
This is a console for interacting with Vodafone dongles.
There are instructions on how to setup a console properly to enable backspace etc, as I didn't make it very general.
Once you have that working can you try the following and post the output (so long as it isn't sensitive, in which case, just describe if you saw anything unusual).
List all messages:
Note that you should type this in at the console (just to be absolutely clear as it looks like a code listing in this forum).
It shouldn't happen on the K3770 or K3772-Z, but I've noticed on others that sometimes things like read-receipts are stored.
Try reading each of the messages and see if the modem reports any errors:
then
and so on.
If the modem produces an error in any of those instances, then something odd is going on.
I also noticed odd errors with SMS on rare occasions, but I started to suspect it was due to the modem being powered on and off so frequently, potentially in the middle of operations. This would be a badly programmed modem, but it's not infeasible.
This could be a total red herring, but it would be interesting to see what happens.
Otherwise we need to find a way to repeat the situation in order to debug it. How often do you send messages to the device?
Ashley
P.S. I'm at MWC, Barcelona today (just landed), and next week so I won't be able to respond as much as normally.
Hi Andrew,
Thanks for reporting this! I have just updated the VodafoneUSBModem libraries which should now be compatible with the rev. 44 library.
Cheers,
Donatien
