Write text into a document
07 Sep 2012
I want to write formatted text into a document. It works only with numbers, but when I write char's with text, then the compiler write the binary numbers instead of it.
Here's my code:
Serial pc(USBTX,USBRX);
    FILE *fp;
    fp = fopen("/local/tabelle.txt", "w");
    if(fp == NULL) {
        pc.printf("Datei konnte nicht geoeffnet werden.\n");
    } else {
        char a[25] = "Zeit";
        char b[25] = "Datum";
        char c[25] = "Startdatum";
        char d[25] = "Enddatum";
        int tabelle[4][4];
        tabelle[0][0] = *a;
        tabelle[0][1] = *b;
        tabelle[0][2] = *c;
        tabelle[0][3] = *d;
        int i, j;
// Loop, Y-Pos
        for(i=0; i<5; i++) {
            // Loop, X-Pos
                for(j=0; j<5; j++) {
                fprintf(fp, "%d ", tabelle[i][j]);
            fprintf(fp, "\n");
    pc.printf("Done.\n");
    fclose(fp);
07 Sep 2012
Hello, can this happen because You use %d in fprintf call?
So can change to
fprintf(fp, "%s ", tabelle[i][j]);
help to print it out as character stream?
07 Sep 2012
I use %s ...but then my mbed crashed o.O' ... it works when I use %d, ... strange ... I don't know ...what I can do?... :/
07 Sep 2012
Try *tabelle[i][j] in the fprintf and use a & instead of a * earlier... That would set tabelle to be pointers to the strings and set the fprintf to recieve the string
07 Sep 2012
Can you write it down, I don't know how I can write it.
07 Sep 2012
    FILE *fp;
    if(fp == NULL) {
    } else {
        int tabelle[4][4];
        tabelle[0][0] = &a;
        tabelle[0][1] = &b;
        tabelle[0][2] = &c;
        tabelle[0][3] = &d;
        int i, j;
// Loop, Y-Pos
            // Loop, X-Pos
                fprintf(fp, "%s ", *tabelle[i][j]);
            fprintf(fp, "\n");
    fclose(fp);
It may need the table declaration to be char* rather than int, however that might work
07 Sep 2012
It doesn't work. :(
The Compiler said: "a value of type "char (*)[25]" cannot be assigned to an entity of type "int"" in file "/main.cpp", Line: 24, Col: 22 "a value of type "char (*)[25]" cannot be assigned to an entity of type "int"" in file "/main.cpp", Line: 25, Col: 22 "a value of type "char (*)[25]" cannot be assigned to an entity of type "int"" in file "/main.cpp", Line: 26, Col: 22 "a value of type "char (*)[25]" cannot be assigned to an entity of type "int"" in file "/main.cpp", Line: 27, Col: 22 "operand of "*" must be a pointer" in file "/main.cpp", Line: 35, Col: 36 "Unable to download. Fix the reported errors..." in file "/"
    FILE *fp;
    if(fp == NULL) {
    } else {
        int tabelle[4][4];
        tabelle[0][0] = &a;
        tabelle[0][1] = &b;
        tabelle[0][2] = &c;
        tabelle[0][3] = &d;
        int i, j;
// Loop, Y-Pos
            // Loop, X-Pos
            fprintf(fp, "\n");
    fclose(fp);
07 Sep 2012
Hello , i made some tests and went out with this.
    FILE *fp;
    if(fp == NULL) {
    } else {
        char *a = "Zeit";
        char *b = "Datum";
        char *c = "Startdatum";
        char *d = "Enddatum";
        char * tabelle[4][4];
        tabelle[0][0] = a;
        tabelle[0][1] = b;
        tabelle[0][2] = c;
        tabelle[0][3] = d;
        int i, j;
// Loop, Y-Pos
            // Loop, X-Pos
            fprintf(fp, "\n");
    fclose(fp);
Strings are printed to file but there is some "garbage" because tabelle is 2 dimensional array and only 4 ellements are inicialized so I assume that in other ellements are random data which are in memmory. So there will be needed initialization of other ellements of tabelle array or use 1 dimensional array like tabelle[4] instead of tabelle[4][4].
07 Sep 2012
This is what I meant in last post only 1 dimensional array.
    FILE *fp;
    if(fp == NULL) {
    } else {
        char *a = "Zeit";
        char *b = "Datum";
        //char * tabelle[4][4];
        char * tabelle[4];
        tabelle[0] = a;
        tabelle[1] = b;
        tabelle[2] = c;
        tabelle[3] = d;
        int i, j;
// Loop, Y-Pos
            // Loop, X-Pos
            //for(j=0; j<5; j++) {
            fprintf(fp, "%s ", tabelle[i]/*[j]*/);
        fprintf(fp, "\n");
    fclose(fp);
But I am not sure if this match Your needs so it seems to be better use code I posted above and inicialize all ellements or print to file only required ellements to not get printed random data from memory.
I am sorry of my bad english because I am from Czech Republic and english is not my origin language.
07 Sep 2012
Ohh, thank you it works :)
The "garbage" is gone, because of this: ;)
char * tabelle[4][4] = {0};
07 Sep 2012
No Problem... I'm from Germany, and my english grammar is bad too ;)
07 Sep 2012
I am happy that works for You.
char * tabelle[4][4] = {0}; Yes, very clever.
If You are from Germany, so we are neighbours:)
