i have written a code that uses Watchdog to reset Mbed every 30seconds. After 30-60mins, the ethernet interface fails to setup() after WD reset.
If i press reset button, ethernet setup() works. How can that be?
#include "EthernetNetIf.h"
EthernetNetIf eth;
void dogKick() {
    LPC_WDT->WDFEED = 0xAA;
    LPC_WDT->WDFEED = 0x55;
    printf("dogkick\n");
void setDog(float s =30) {
    LPC_WDT->WDCLKSEL = 0x1;                // Set CLK src to PCLK
    uint32_t clk = SystemCoreClock / 16;    // WD has a fixed /4 prescaler, PCLK default is /4
    LPC_WDT->WDTC = s * (float)clk;
    LPC_WDT->WDMOD = 0x3;                   // Enabled and Reset
    dogKick();
    printf("\n\nStartup...\n");
    setDog(30);
    wait(1);
    printf("Setting up...\n");
    EthernetErr ethErr = eth.setup(30000);// lets use 30seconds, problem is with default value also
    if (ethErr) {
        printf("Error %d in setup.\n", ethErr);
        return -1;
    printf("Setup OK\n");
    return 0;
Hm, and i have also used a reset on PHY chip on mbed like that
DigitalOut ethrst(P1_28);
int main{
    ethrst=0;//reset active low
    wait(1);
    ethrst=1;
    wait(1);
  //code continues....
Seems to work a bit longer.
Ideas?
#include "mbed.h" #include "EthernetNetIf.h" EthernetNetIf eth; void dogKick() { LPC_WDT->WDFEED = 0xAA; LPC_WDT->WDFEED = 0x55; printf("dogkick\n"); } void setDog(float s =30) { LPC_WDT->WDCLKSEL = 0x1; // Set CLK src to PCLK uint32_t clk = SystemCoreClock / 16; // WD has a fixed /4 prescaler, PCLK default is /4 LPC_WDT->WDTC = s * (float)clk; LPC_WDT->WDMOD = 0x3; // Enabled and Reset dogKick(); } int main() { printf("\n\nStartup...\n"); setDog(30); wait(1); printf("Setting up...\n"); EthernetErr ethErr = eth.setup(30000);// lets use 30seconds, problem is with default value also if (ethErr) { printf("Error %d in setup.\n", ethErr); return -1; } printf("Setup OK\n"); return 0; }Hm, and i have also used a reset on PHY chip on mbed like that
DigitalOut ethrst(P1_28); int main{ ethrst=0;//reset active low wait(1); ethrst=1; wait(1); //code continues.... }Seems to work a bit longer.
Ideas?
