HID USB data rate
  Selim Olcer.
                        8
                        replies
  Vincent Donnefort wrote:
I need to send to the Mbed 528bytes 25 times per second.
So I used HID USB on mbed and HIDAPI on my computer (with Qt). I make messages from 63bytes (and I add a "0x00" Report ID) to send a complete transfert to the mbed.
It works great but the data rate transfert is really bad (8kB/s to send the 528bytes...) I don't see how I can improve this rate. Can you help me?
Thanks a lot!
Dear Vincent,
could you find any solution for improve the data rate?
Selim.
Concerning the HID usb interface, you can send up to 64bytes each millisecond (64 kBytes/s). For that you have to use:
USBHID hid(64, 64);
send_report.length = 64;
for (int i = 0; i < send_report.length; i++) {
    send_report.data[i] = rand() & 0xff;
//Send the report
hid.send(&send_report);
Hope that helps
Sam
Hi Samuel,
Thanks for reply.
I tried as you wrote. It worked fine at 64kb/s. I tried my code after that . It also worked same data rate (I didn't do any changes on my code). But my code is works 8kb/s when I power off and power on the mbed. Why does it happen You think?
Selim.
Hi Selim,
I didn't understand very well. When you try my code, the rate is 64kBytes/s and when you use your code, the rate is 8kBytes/s ?
Sam
  Samuel Mokrani wrote:
Hi Selim,
Sam
Samuel,
Your code works very well at 64 KB/s while mine works at 8 KB/s. But if i test my code after testing yours keeping the usb cable plugged in, my code also works at 64 KB/s. However, if i unplug the usb cable after testing your code and re-plug it (i.e. restart the mbed) my code goes back to work at 8 KB/s.
Selim.
Hi Selim,
Sam
Samuel,
Selim.
Meanwhile, my usb definitions in my code is same in yours
Hello Selim, are You using ticker in Your code? Can You please post Your code? I am also interested in "what is going on"?
No, I don't use ticker but I use adc interrupt. my code is:
#include "USBHID.h"
#include "stdio.h"
#include "tanimlamalar.h"
void adcInit(uint32_t ADC_Clk );
extern "C" void ADC_IRQHandler (void) __irq ;
uint32_t ADCRead( uint8_t );
void sinyalVer(void);
volatile uint32_t OverRunCounter = 0;
volatile uint32_t ADCIntDone = 0, tumPiksellerOkundu = 0;
void changeRowCol(unsigned char row, unsigned char column);
void changeRowColOwnCode(unsigned char row, unsigned char column);
unsigned int rowBusData[64] = {0,512,64,576,2,514,66,578,256,768,320,832,258,770,322,834,1,513,65,577,3,515,67,579,257,769,321,833,259,771,323,835,128,640,192,704,130,642,194,706,384,896,448,960,386,898,450,962,129,641,193,705,131,643,195,707,385,897,449,961,387,899,451,963};
//We declare a USBHID device. By default input and output reports are 64 bytes long.
//USBHID hid(64,8 ,0x1234,0x0006);
USBHID hid(64, 64);
//This report will contain data to be sent
HID_REPORT send_report;
HID_REPORT recv_report;
//AnalogIn adcCInput(p16);        //Cartesian array i�in analog giri�
PwmOut pwm(p21);
DigitalOut adcToggle(p20);      //adc okurken toggle yap�p kontrol ediyorum sadece
DigitalOut transmitLed(LED1);
DigitalOut receiveLed(LED2);
DigitalOut debugLed(LED3);
DigitalOut donguLed(LED4);
BusInOut cRowBus(p5, p8, p10, p6, p9, p7);      //Cartesian array sat�r pinleri. s�ras� �nemli
BusInOut cColBus(p25, p26, p29, p27, p28, p30); //Cartesian array s�tun pinleri
volatile unsigned char mainStateMachine =0, colIndex=0,rowIndex=0,sayac=0,colIndexTemp=0,rowIndexTemp=0 ;
volatile unsigned int pixels[64][64],adcValue,averageCount,tempInteger,tempInteger1;
volatile unsigned long averageValue;
float pwmDutyCycleValue=0.50;
unsigned int pwmPeriodUs=654;
char c=0;
    cColBus.mode(OpenDrain);
    cColBus.output();
    cRowBus.mode(OpenDrain);
    cRowBus.output();
    pwm.period_us(pwmPeriodUs);
    pwm = pwmDutyCycleValue;
    if (averageCount==0) averageCount=1;
    mainStateMachine=bekle;
    adcInit(13000000);
    ADCRead(1);
        if (OverRunCounter>0) {
                donguLed=~donguLed;
                wait_ms(500);
        //try to read a msg
        if (hid.readNB(&recv_report)) {
            receiveLed = !receiveLed;
            switch (recv_report.data[komut]) {
                case sadeceBirPikselOku:
                    rowIndexTemp=recv_report.data[2];           // istenen piksel numaras�n� sakl�yorum.
                    colIndexTemp=recv_report.data[3];
                    //changeRowCol(rowIndex,colIndex);        //uygun kanala gec
                    averageCount=recv_report.data[4]*256;   //Average de�erini al
                    averageCount+=recv_report.data[5];
                    send_report.data[0]=sadeceBirPikselOku;     //Komut
                    send_report.data[1]=rowIndexTemp;               //Parametre 1
                    send_report.data[2]=colIndexTemp;               //Parametre 2
                    send_report.data[3]=(char)((pixels[rowIndexTemp][colIndexTemp])>>8&0x00FF);
                    send_report.data[4]=(char)((pixels[rowIndexTemp][colIndexTemp])&0x00FF);
                    send_report.data[5]=(char)((int)(pwmDutyCycleValue*1000)>>8&0x00ff);
                    send_report.data[6]=(char)((int)(pwmDutyCycleValue*1000)&0x00ff);
                    send_report.data[7]=(char)((averageCount>>8)&0x00ff);
                    send_report.data[8]=(char)(averageCount&0x00ff);
                    transmitLed=!transmitLed;
                    break;
                case averageSayisiYaz:
                    averageCount=recv_report.data[2]*256;
                    averageCount+=recv_report.data[3];
                    break;
               case tumunuToptanGonder:
                    for (rowIndexTemp=0; rowIndexTemp<64; rowIndexTemp++) {
                        for (colIndexTemp=0; colIndexTemp<32; colIndexTemp++) {
                            send_report.data[(colIndexTemp*2)]=(char)(pixels[rowIndexTemp][colIndexTemp] >> 8) & 0x00FF;
                            send_report.data[(colIndexTemp*2)+1]=(char)(pixels[rowIndexTemp][colIndexTemp] & 0x00FF);
                        for (colIndexTemp=32; colIndexTemp<64; colIndexTemp++) {
                            send_report.data[(colIndexTemp-32)*2]=(char)(pixels[rowIndexTemp][colIndexTemp] >> 8) & 0x00FF;
                            send_report.data[(colIndexTemp-32)*2+1]=(char)(pixels[rowIndexTemp][colIndexTemp] & 0x00FF);
                    break;
                case pwmPeriyodYaz:
                    tempInteger=recv_report.data[2]*256;       //  pwmFrekans i�in gelen us cinsinden periyot s�resi
                    tempInteger+=recv_report.data[3];
                    if (tempInteger>0) {
                        pwm.period_us(tempInteger);
                    tempInteger=recv_report.data[4]*256;        //  pwmDutyCycle degeri
                    tempInteger+=recv_report.data[5];
                    pwm = (float)tempInteger/1000;
                    pwmDutyCycleValue=pwm.read();
                    break;
            }   // switch recv_report.data
        } //if (hid.readNB(&recv_report))
    }  //while(1)
}   //main
void changeRowCol(unsigned char row, unsigned char column) {
    cRowBus.write(row);
    cColBus.write(column);
void adcInit(uint32_t ADC_Clk) {
    uint32_t  pclkdiv, pclk;
    /* Enable CLOCK into ADC controller */
    LPC_SC->PCONP |= (1 << 12);
    /* all the related pins are set to ADC inputs, AD0.0~7 */
    LPC_PINCON->PINSEL1 &= ~0x00030000;     //p0.24 fonksiyonunu s�f�rlar
    LPC_PINCON->PINSEL1 |=  0x00010000;     //p0.24'�n� ad0.1 fonksiyonuna atar
    /* No pull-up no pull-down (function 10) on these ADC pins. */
    LPC_PINCON->PINMODE1 &= ~0x00030000;      //p0.24 pinmode s�f�rlar
    LPC_PINCON->PINMODE1 |=  0x00020000;      //p0.24 pull-up or pull-down yok
    /* By default, the PCLKSELx value is zero, thus, the PCLK for
    all the peripherals is 1/4 of the SystemCoreClock. */
    /* Bit 24~25 is for ADC */
    pclkdiv = (LPC_SC->PCLKSEL0 >> 24) & 0x03;
    switch ( pclkdiv ) {
        case 0x00:
        default:
            pclk = SystemCoreClock/4;
            break;
        case 0x01:
            pclk = SystemCoreClock;
            break;
        case 0x02:
            pclk = SystemCoreClock/2;
            break;
        case 0x03:
            pclk = SystemCoreClock/8;
            break;
    LPC_ADC->ADCR = ( 0x01 << 1 ) |  /* SEL=1,select channel 0~7 on ADC0 */
                    ( ( pclk  / ADC_Clk - 1 ) << 8 ) |  /* CLKDIV = Fpclk / ADC_Clk - 1 */
                    ( 0 << 16 ) |         /* BURST = 0, no BURST, software controlled */
                    ( 0 << 17 ) |          /* CLKS = 0, 11 clocks/10 bits */
                    ( 1 << 21 ) |          /* PDN = 1, normal operation */
                    ( 0 << 24 ) |          /* START = 0 A/D conversion stops */
                    ( 0 << 27 );        /* EDGE = 0 (CAP/MAT singal falling,trigger A/D conversion) */
    /* If POLLING, no need to do the following */
    NVIC_EnableIRQ(ADC_IRQn);
    //LPC_ADC->ADINTEN = 0x1FF;        /* Enable all interrupts */
    LPC_ADC->ADINTEN = 0x102;
    return;
extern "C" void ADC_IRQHandler (void) __irq {
    uint32_t regVal;
    volatile uint32_t dummy;
    regVal = LPC_ADC->ADSTAT;        /* Read ADC will clear the interrupt */
    if ( regVal & 0x0000FF00 ) {    /* check OVERRUN error first */
        OverRunCounter++;
        regVal = (regVal & 0x0000FF00) >> 0x08;
        /* if overrun, just read ADDR to clear */
        /* regVal variable has been reused. */
        dummy = LPC_ADC->ADDR0;
        dummy = LPC_ADC->ADDR1;
        dummy = LPC_ADC->ADDR2;
        LPC_ADC->ADCR &= ~((0x7<<24)|(0x1<<16));    /* stop ADC now, turn off BURST bit. */
        ADCIntDone = 1;
        return;
    adcValue = ( LPC_ADC->ADDR1 >> 4 ) & 0xFFF;
    pixels[rowIndex][colIndex]=adcValue;
    if (colIndex<63) {
        colIndex++;
    } else {
        colIndex=0;
        rowIndex++;
        if (rowIndex==64) {
            rowIndex=0;
    //  LPC_ADC->ADCR &= ~(0x7<<24);    /* stop ADC now */
    LPC_ADC->ADCR |= (1 << 24) ;        //ADC durmadan devam ediyor.
    ADCIntDone = 1;
    return;
** Function name:        ADCRead
** Descriptions:        Read ADC channel
** parameters:            Channel number
** Returned value:        Value read, if interrupt driven, return channel #
uint32_t ADCRead( uint8_t channelNum ) {
    //LPC_ADC->ADCR &= 0xFFFFFF00;
    LPC_ADC->ADCR |= (1 << 24) ;//| (1 << channelNum);
    /* switch channel,start A/D convert */
    return ( channelNum );    /* if it's interrupt driven, the ADC reading is
                            done inside the handler. so, return channel number */
void sinyalVer(void) {
    debugLed=1;
    wait_ms(100);
    debugLed=0;
    wait_ms(100);
    debugLed=1;
    wait_ms(100);
    debugLed=0;
Thanks a lot!
