Edited:
A 1 Mhz bit-rate is the fastest that CAN is rated. I haven't studied the configuration on the LPC1768 to see if it could be programmed to exceed that speed. I think 10 kb/s is the low end, and some transceivers can't go that low.
Note that most, but not all, of the commercially available CAN transceivers are rated for 1 Mb/s. There is a lower-speed transceiver that has additional diagnostics, but I think it is only rated for 125 Kb/s. Many of the baseboards listed on this site have CAN transceivers - you might want to study the schematics for them.
Here's a short sample of transceivers. There's nothing special about this list, and you'll find parts differ in speed, power consumption, diagnostics, voltage tolerance, signal wave-shaping, silent-mode, and more:
- Infineon TLE6255G: Low speed single-wire up to 33kb/s, high speed mode up to 110 kb/s
- On Semi NVC7341: High speed up to 1 Mb/s
- NXP TJA1050: High speed up to 1 Mb/s
- NXP TJA1054: Low Speed up to 125 kb/s
- Atmel B10011S: Low speed up to 1Mb/s
- Microchip MCP2551: 1Mb/s
As you see, even the definition of speed isn't consistent.
Hello everyone,
what is the maximum CAN frequency? Is it 1MHz? I would like to connect two mbeds via CAN bus.
