global visibility of functions etc.
19 Jun 2009
I am currently using the following
DigitalOut User_Led1(LED1);
AnalogIn AD0(15);
Serial pc(USBTX, USBRX);
and wish to use the same syntax in other modules of code. If i include these at the start of the code or in a header file the linker complains of multiple definitions. If i exclude them the the compiler complains that the the are not defined.
As i wish to use such lines as
  pc.printf("Welcome the the MBED Developers Module\n\r");
and
User_Led1 = LED_OFF;
in other C source modules, how do i go about doing this ?
19 Jun 2009
Hi Mike,
AnalogIn AD0(15);
The key is to not get too caught up in the fact these are mbed Interfaces; it is just C/C++. So you just use the standard approach you would for any variable you'd want to use from multiple files.
So what you'll need to do is create the variables/objects in a source file, and define them as extern in a header file, which can be included by anyone who wants to use them.
I've written an example showing it:
http://mbed.co.uk/projects/cookbook/svn/examples/MultipleUsers
If in the compiler if you "Import Project" > "SVN" and use the above url, you should have a working example you can try/fiddle with yourself.
Does this solve your problem (or did I miss the point?!).
22 Jun 2009
thanks for this. I've created a global include for the I/O structure.
Best regards
David Giles
