TCP socket Events
18 Apr 2011
Hi, I´m using the TCPSocket library. When I receive something, the event WRITEABLE occurs and I´d wanted to know if it is possible , after recv, to send something inside the case of TCPSocket_WRITEABLE envent... Thanks for your help and regards, María.
18 Apr 2011
Yes, you can do this. But you still need to call Net:poll() outside of the event handler, so you will need some code in your main loop. Thats why most TCP programs use the event handler for signaling the current state to a main loop, which does the heavy lifting.
18 Apr 2011
The event WRITEABLE occurs when you send data and not when you receive!
10 May 2011
Yes, I meant that. WRITEABLE event occurs after a send always? I mean, the way to know if a send was executed correctly is seeing if the WRITEABLE event occurs (suposing that I don´t receive anything on the other side). thanks
