filenaming
06 Aug 2010
I have an issue with creating and naming files for data storage.
This is the method I use now:
char filename[64];
sprintf(filename, "/local/analog_%d.txt", x);
FILE *fp = fopen(filename, "w");
where x is an incremented variable which changes after a file has been opened, so that the next file is named the next highest number.
Unfortunately, this limits me to 10 files at most.
Is there a simple solution to this?
here is what I thought of using:
    char filename[64];
          for (x=x; x<10; x=x) {
            sprintf(filename, "/local/analog_000%d.txt", x);
          for (x=x; 10<100; x=x) {
            sprintf(filename, "/local/analog_00%d.txt", x);
          for (x=x; 100<1000; x=x) {
            sprintf(filename, "/local/analog_0%d.txt", x);
          for (x=x; 1000<10000; x=x) {
But this is pretty ugly (plus it dosen't work, hangs up mbed on start-up)
any suggestions?
thanks
06 Aug 2010
%d gets replaced by the actual number passed to printf, not just one digit, so you're not "limited" to 10 files. If you want to insert additional zeroes, use the zero-padding modifier:
sprintf(filename, "/local/analog_%05d.txt", x);
This will pad the decimal value with zeroes if it's less than 5 digits long.
P.S. your for() operators are wrong, that's why mbed hangs (it actually enters infinite loop). You probably want something like this:
for ( x=1; x<100; x++)
06 Aug 2010
yea, I was improvising, I don't want the for operation to change the value of x.
I know, the naming scheme looks sound, you'd think after 9 it would just make a file called 10, but it doesn't, it writes 10 file from 0-9 then stops, the rest of the program runs, and even records data, but the 10 original files stay, and no more are added. x is just some integer than I have increment after data has been written to the file and the file closed.
06 Aug 2010 . Edited: 06 Aug 2010
Isn't there an 8.3 filename limit on the mbed?
Try changing your filename to something shorter - at the moment "analog_" uses 7 of the 8 characters, so you've only got one left for your number.
How about:
 sprintf(filename, "/local/an_%d.txt", x);
06 Aug 2010
thats it! thanks man, I was stuck on that one.
