Hi Simon:
 Thank you for your response and for trying to provide a way to accomplish what I am trying to do.  I think I will wait until I learn how to build a library as we have been discussing in another thread.  What you have posted here is beyond my understanding at this time.  It looks to me as though I would have to add TextLCD.h which does not resemble the LCD I am using.
 As an example, here is the structure of each of the functions that I have defined.  I could likely reduce the number of functions I have defined by finding a different way of representing the "LCD_option" variable as that variable is the only thing that changes in each module to accomplish other tasks such as turning the cursor on and off.
//* Clear Screen
void LCD_clear_screen(int LCD_command, int LCD_option)
   LCD_command = 0xFE;             // command designator
   LCD_option  = 0x58;             // Clear Screen
   char cmd[2];
   cmd[0] = LCD_command;           // 0xFE
   cmd[1] = LCD_option;            // 0x58
   LCD.write(LCD_address, cmd, 2); // Send command element
// The functions that position the cursor are all based on:
//* Set Cursor Position
void LCD_cursor_position(int LCD_command, int LCD_option, int LCD_col, int LCD_row)
   LCD_option  = 0x47;             // Set Cursor Position
   char cmd[4];
   cmd[1] = LCD_option;            // 0x47
   cmd[2] = LCD_col;               // Valid = 1 - 16
   cmd[3] = LCD_row;               // Valid = 1 - 2
   LCD.write(LCD_address, cmd, 4); // Send command elements
// which really is the same function with the inclusion of passing the col and row information to the existing command function.
 In order to pass a line of text to the LCD, I once again use the same structure, with the exception that I have specified char letters[17] instead of cmd[1-4].  I have discovered that I can pass ascii characters instead of hex characters as indicated below.
// LCD Write First Row Init Function
void LCD_First_Row(int LCD_address)
     char letters[17];
     letters[0]  = 'D';   //D
     letters[1]  = 'i';   //i
     letters[2]  = 0x73;  //s
     letters[3]  = 0x70;  //p
     letters[4]  = 0x6C;  //l
     letters[5]  = 0x61;  //a
     letters[6]  = 0x79;  //y
     letters[7]  = 0x2E;  //.
     letters[8]  = 0x2E;  //.
     letters[9]  = 0x2E;  //.
     letters[10] = 0x2E;  //.
     letters[11] = 0x20;  //
     letters[12] = 0x52;  //R
     letters[13] = 0x65;  //e
     letters[14] = 0x61;  //a
     letters[15] = 0x64;  //d
     letters[16] = 0x79;  //y
     LCD.write(LCD_address, letters, 17); // Send data elements
} I would like to be able type the text that I wish to send as just "Display Ready" (with the appropriate number of blank spaces to match the number of characters per line and then send it to the LCD as such.
 Right now, I can say what is written below and I have complete control of the LCD.
 main()
    while(1)
       LCD_clear_Screen;
       wait(1);
       LCD_First_Row;
       LCD_Second_Row;
 I had to edit this reply because I couldn't add a new line after the code box containing main().  I don't know why it works like that but it does.
 If I am displaying a variable, I used
 LCD.write(LCD_address, tagValue, 10);
 where tagValue is a char array.
 I'm sure that there is a more efficient way of doing all of this, but this is what I developed to easily communicate with I2C devices.  I don't see a way of changing this to match what you have outlined given my current approach.
 I am open to suggestions for improvement but for now I will leave things as is until I can understand what is involved in building a library.
 I do appreciate your attempt to help and I wish I understood it.  I just thought it would be convenient to write to the LCD in the same fashion as I use pc.printf to write to the serial terminal.
 Thanks
 Tim
Hi.
I have noticed that in the samples for writing to a serial display, putc, and printf are used.
I am using an I2C display and would like to be able to use these functions. In looking at the I2C LCD examples they all make use of the LCD as a parallel display (ie, _rw, _rs, _e, (4 bit lines)).
My LCD is pure I2C where the interface on the display handles the connection to the LCD and I need only to send it hex codes for commands and characters.
Using putc and printf would greatly simplify my interface.
Is there a way to add these to my I2C?
Thanks
Tim
