Hi confucius carpentier,
As you see from Sukkin Pang, you can get started with CAN quite simply on a proto board. If your needs are for something a bit more rugged, the Smartboard Baseboard I designed lets you create such a solution.
Yes, that board supports Ethernet, USB, an SD card, and more, but you do not need to buy or install the parts you will not use, so you might only need the mbed connector, the CAN related parts, the screw terminal connectors, and the power supply.
If you are early in your experimenting, then a small breakout board is probably the better way to go.
Hi everyone, I'm a beginner in electronics and I bought two MBED LCP1768. I'm trying to test if each one works well with CAN. Therefore I made a simple assembly with an MCP2551 and a CAN generator. TX and RX are pins 29 and 30 of a mbed.
I tried with the "hello world" CAN program but I failed to see any reaction from the mbed! I don't know what I did wrong. Any assembly or program to make a bus can work would be cool.
