Serial: Printf and Scanf a string
10 Aug 2011
Hello! I'm trying to send a string from one mbed to another using the Serial functions printf and scanf and it doesn´t works. The code I have on the mbed who sends is the next:
Serial micro(p9, p10);//tx, rx
Serial pc(USBTX,USBRX);//tx, rx
const char command[9]={0xF2, 0x00, 0x09, 0xff, 0x22, 0x00, 0x05, 0x79, 0x6F};
int err;
    micro.format(8, Serial::None, 1);
    micro.baud(19200);
    pc.format(8, Serial::None, 1);
    pc.baud(9600);
    while (true) {
        if (micro.writeable()) {
            err=  micro.printf(command);
            break;
    pc.printf("Printf returns: %d\r\n", err);
And in the mbed who receives:
int err;
char command[9];
    micro.baud(19200);
    pc.baud(9600);
    while (true) {
        if (micro.readable()) {
            err= micro.scanf(command);
            break;
    pc.printf("Command Received: \r\n");
    for (int i=0;i<sizeof(command);i++){
    pc.printf("%X",command[i]);
    pc.printf("\r\n");
    pc.printf("Scanf returns: %d\r\n",err);
After executing the scanf works but it receives all 0 and returns a 0 too. I use the USBTX and USBRX to see in the Terminal what is happening. I tried too using "%s" before the string (micro.scanf("%s", command)) but in this way, I don´t receive anything. The scanf doesn´t work. I also realized that the printf and the scanf returns an integer, but I have no idea what it means (I didn't find information anywhere)
Does anybody what is wrong in my code?
Thank you so much!!!!
María.
10 Aug 2011
Thank you! I´ll use putc and getc.
16 Aug 2011
I´m using now putc and getc but I have a problem. If I send, for example, 22 bytes using putc, I only can receive on the other side the 16 first bytes. Is there any size limit to send and receive chars? Thank you so much!
16 Aug 2011
You could try calling fflush(stdout); after you send the 22 bytes to make sure that they don't just sit in a buffer.
16 Aug 2011
I call fflush(stdout) after sending the 22 bytes and it´s the same. On the other mbed I just receive the 16 first bytes. Have you any idea? Thanks a lot!
17 Aug 2011
why you don't use interrupts to catch the incoming data?
Something like this:
#include <string>
string b;
newData(void) {
    //buffer variables
    char lezen;
    //if data is ready in the buffer
    while (zender.readable()) {
        //read 1 character
        lezen = micro.getc();
        //if character is $ than it is the start of a sentence
        if (lezen == '$') {
            //so the pointer should be set to the first position
            b.clear();
        //write buffer character to big buffer string
        b += lezen;
        //if the character is # than the end of the sentence is reached and some stuff has to be done
        if (lezen == '#') {
            char * cstr, *p;
            string c1,c2,c3,c4;
            int set = 1;
            int n;
            float f;
            //remove start and stop characters
            b.erase(0,1);
            b.erase(b.length()-1,1);
//do something witth string b, like:
if (b=="some command"){
de something
main(){
micro.attach(&newData);
01 Sep 2011
Hi! I realized that if after the putc I send something to the USBRX pin, it works. The code is the next:
  for (int i=0; i<long_command; i++) {
                        while (true) {
                                result =  micro.putc(command[i]);
                                pc.printf("Putc result: %X\r\n",result);
                                break;
But, I don´t understand why it works in this way. Serial pins and USB pins use the same buffer? What is the relationship between them?
Does anybody know how it works??
Thanks!!
María.
01 Sep 2011
what exactly are you trying to accomplish?
<<quote>>Hello! I'm trying to send a string from one mbed to another using the Serial functions printf and scanf and it doesn´t works. The code I have on the mbed who sends is the next:<</quote>>
the best way to accomplish this is using an interrupt. Basically, if something arrives on the serial port on your receiving mbed, it automatically saves the data someplace where you can process later
<<quote>>But, I don´t understand why it works in this way. Serial pins and USB pins use the same buffer? What is the relationship between them?<</quote>>
They probably have different buffers
                        while (true) {
                                break;
is this the code on the transmitter?
01 Sep 2011
Yes, it´s in the transmitter. I´m sending a string from one mbed to another using putc and getc because they are binary data. The problem is that without the pc.printf only I can send 16 bytes.
01 Sep 2011
I think I know the problem
on the transmitter side
for(counter=0; counter<"length of string"; counter++) { serial_send.putc(command[counter]); wait(0.1); <<this is crucial as the receiver cannot react right away when a character arrives at the serial receiver }
The transmitter side is fine. The problem is on the receiver side. If you have other processes running on it, then the receiver may not be able to retrieve the character before a new character arrives. You can prevent this by using interrupts. That way, as soon as a character arrives at the serial port, the receiver can react right away and copy this character to a buffer somewhere.
01 Sep 2011
Thanks, I know that with interrupts is possible , but my question is if anybody knows why is there a relationship between the putc on the serial pins and the printf on the USB pins... It works without interrupts but I don´t know why... it´s a mistery :-)
01 Sep 2011
Im assuming the pc.printf("something") introduces somewhat a sufficient delay before a new character is send over the serial port.This gives time on your receiver to process the data.
The usb-to-serial is connected to a different serial port than what you're using
30 Apr 2012
Maria,
Could I have a copy of your working code please? I'm trying to achieve similar.
Did you use interrupts in the end?
Craig
02 May 2012
Hi Craig, Finally, I didn´t use interrupts, just the delay that te printf to de USB port introduce. Here you are the code to send:
  while (true) {
                        err=micro.putc(long_response);
                        break;
                pc.printf("Response sent:\r\n");
                for (int i=0; i<long_response; i++) {
                    while (true) {
                            err=  micro.putc(response[i]);
                            pc.printf("%X", err);
                            break;
                pc.printf("\r\n");
Where "long_response" is the size of the buffer you want to send. I send first this information to manage the loop on the reciving side.
And to receive:
  while (true) {
                        size_command=micro.getc();
                        break;
                char command[size_command];
                pc.printf("Command received:");
                for (int i=0; i<size_command; i++) {
                    while (true) {
                            command[i]= micro.getc();
                            pc.printf("%X", command[i]);
                            break;
                pc.printf("\r\n");
Where "size_command" is the size of the buffer I send first on the other side.
I hope you can understand something :P
María.
25 Jun 2014
Could someone please place the entire code. I'm having problems following this. Thank you
29 Apr 2016
/media/uploads/sour/doudt.png
in this code section before running scanf "j =1" and after scanf function again j=1, can somebody tell me, after taking data from scan why readable()'s output is not zero, while i am sending only one string.
29 Apr 2016
scanf("%s") will read up to the first whitespace character. The transmitted string includes "\r\n" at the end, they both count as whitespace. So you buffer isn't empty because it still contains two bytes, '\r' and '\n'.
16 May 2016
Somebody else may take issue with this but I would suggest you don't try to use scanf on incoming data generally unless you are communicating with an operator and you don't mind the program blocking waiting for input.
I wouldn't recommend scanf for m2m, I think it would be better to pull in characters with getc, assemble them into a string and then you might use sscanf to convert values.
26 May 2016
try lower rate 9600 in place of 19200..
13 Jan 2017
It is often useful to use some more advanced RS232 terminal program to see all received data even if not ASCII readable format. For example http://docklight.de/ or similar one.
Then you can see 0x00 enter or any other special character that user is not aware that is sent since it is not ASCII visible character..
