You could just tell main.cpp that there is a global pc object located in some other module like this:
#include "hello_class.h"
extern Serial pc;
hello_class myObj;
myObj.hello();
pc.printf("\nHello From MAIN"); /* HELLO FROM MAIN */
If this is the route that you go, you might want to define the pc object in main.cpp and add the extern to hello_world.cpp instead so that if you add other modules, they will all point back to the one defined by the main module.
Another method might be to have main.cpp create the Serial object and then pass a reference to the hello_class object when it is constructed. This wouldn't require any globals which you may or may not prefer.
main.cpp
Serial pc(USBTX, USBRX);
hello_class myObj(pc);
myObj.hello();
hello_class.h
class hello_class
public:
hello_class(Serial& serialObject);
void hello(); /* Declaration of the function */
protected:
Serial& pc;
hello_class.cpp
hello_class::hello_class(Serial& serialObject) : pc(serialObject)
void hello_class::hello ()
pc.printf("\nHello World!\n");
Ok this is a C++ question,
How can I write to one serial port from a class and from main?
If i have main like this:
hello_class.h
And hello_class.cpp
This Works!
I can read Hello World! on serial
but how can i write something like this:
is it posible or not???
