Problem with Hardware SPI
08 Nov 2010
Hi
i wrote a small test programm, before porting my whole stack to my mbed. I tried it with the hardware SPI class first, it didn't work so i wrote a Software SPI for testing.
DigitalOut sel(p10);
DigitalIn irq(p9);
DigitalOut sdi(p11);
DigitalIn sdo(p12);
DigitalOut sck(p13);
void InitRFModule()
    sel.write(1);
    sdi.write(1);
    sck.write(0);
    wait(1);
    RFWrite(0x80D8);
    RFWrite(0x8201);
    RFWrite(0xA640);
    RFWrite(0xC647);
    RFWrite(0x94A0);
    RFWrite(0xC2AC);
    RFWrite(0xCA81);
    RFWrite(0xCED4);
    RFWrite(0xC483);
    RFWrite(0x9850);
    RFWrite(0xCC77);
    RFWrite(0xE000);
    RFWrite(0xC800);
    RFWrite(0xC040);
    wait(1);
short RFWrite(short b)
    char i;
    short temp = 0;
    sck.write(0);
    sel.write(0);
    for(i = 0; i < 16; i++)
        if(b & 0x8000)
            sdi.write(1);
        else
            sdi.write(0);
        sck.write(1);
        temp <<= 1;
        if(sdo.read())
            temp |= 0x0001;
        sck.write(0);
        b <<= 1;
    sel.write(1);
    return temp;
void RFSend(char b)
    while(irq.read());
    RFWrite(0xB800 + b);
void SEND()
    int i;
    char checksum;
    RFWrite(0x0000);
    RFWrite(0x8239);
    checksum = 0;
    RFSend(0xAA);    //Preamble
    RFSend(0xAA);
    RFSend(0xAA);
    RFSend(0x2D);    //Sync HI
    RFSend(0xD4);    //Sync LO
        RFSend(0x20 + i);
        checksum += (0x20 + i);
    RFSend(checksum);
    RFSend(0xAA);
    RFSend(0xAA);
    RFSend(0xAA);
    RFWrite(0x8201);
    InitRFModule();
    for(;;)
        wait(1);
        SEND();
it worked well, and my receiver got all the data.
So now im trying to use the hardware SPI class. I added following code
SPI spi(p11, p12, p13);
//modified my RFWrite
    short temp = 0;
    sel.write(0);
    temp = spi.write( b );
    sel.write(1);
    return temp;
    //Added SPI Init to main method
    spi.format( 8, 0 );
    spi.frequency( 125000 );
bot the RF Module doesn't send anything, it doesn't even get initalized.
I cant find my mistake, mode 0 should be right (isn't it?).
can anyone help me out?
dominik
08 Nov 2010
Looks to me like your first test program is sending a short (16bit) value. But then with the Mbed library version you set it up to be 8bit, pass in a short, and then only send 8 bits?
09 Nov 2010
thanks for your answer.
you are completely right. i also tried it with 16... i just experimented a bit with the mode and the bits and it doesnt work with 16 or with 8 when i send two packages after another...
any other ideas?
regards
Dominik
09 Nov 2010
btw: should be (or get an stack) for the RFM12 you can buy at Pollin...
16 Nov 2010
Hello
I work with the RFM 12 too and use this functions. I have no Problems with it.
// Send Command to RFM12
int rfm_cmd(short int Wert ) {
    cs = 0;                         //select the Chip PIN 8
    wait( 0.001);                   //wait a little bit, or it will not work
    spi.write(Wert);
    wait(0.001);
    cs = 1;
    return  0;
//Read one byte from the RFM
unsigned char rfm_read() {
    unsigned char data;
    cs =0;
    data = spi.write(0xB000);
    cs = 1;
    return data;
Spi is like this
spi.format(16,0);
spi.frequency(2000000);
to use
rfm_cmd(0x0000);        //read Status
Hope i could help
Dieter
