Notice the void which says "this function returns no value". Without a return type specifier the compiler will automatically assume int.
You haven't supplied a return type. Try:-
<<code>>
void Write_Command(unsigned char command){
nRD = 1;
DB = command;
RS = 0;
nWR = 0;
CS = 0;
CS = 1;
nWR = 1;
<</code>>
Notice the **void** which says "this function returns no value". Without a return type specifier the compiler will automatically assume **int**.
Cookie Policy
Access Warning
Hello. When I compile the code below I get the following error
"Explicit type is missing ("int" assumed) (E260-D)" in file "/main.cpp"
Any ideas to put me on the right track?
Here is the code.
nRD = 1;
DB = command;
RS = 0;
nWR = 0;
CS = 0;
CS = 1;
nWR = 1;
