Dear all,
I notice when I include the code for defining types (see below) I get the error message
""uint32_t" has already been declared in the current scope (E101)" in file "temp100/misra_types.h"
I have recently upgraded from library version 9 to lbrary version 19 and the problem was not vissible before. I presume the new library has defined in it somewhere the typedef relating to uint32_t
Can you suggest a work around? What other types have been defined and where can i find them.
Best Regards
David Giles
/* Bytes (8bit length) */
typedef unsigned char uint8_t;
typedef char sint8_t;
/* Half Words (16bit lengths) */
typedef unsigned short uint16_t;
typedef short sint16_t;
/* Words (32bit lengths) */
/* Also int */
typedef unsigned long uint32_t;
typedef long sint32_t;
/* Double Words */
/* Also long long and long double */
typedef unsigned long long uint64_t;
typedef long long sint64_t;
Dear all,
Best Regards
David Giles
/* Also int */
/* Double Words */
