I authored and maintain the RA8875 Based Display library.
I do have permissions to "Edit this component". After some recent work to the library, and updating of that page, I noticed the "Edit Mbed Enabled Features". I wasn't sure exactly what that was (so naturally I clicked on it). I soon after discovered that it provides filtering for the hardware and components searching, but I didn't find a combination where any components appeared after applying a filter.
As a "component" library provider, I'm not sure what the expectations are, so I wanted to use my own interpretation - to indicate known compatibility with OS versions. I've extensively used OS 2, and done a fair amount of testing with 5.9 and 5.10, so I wanted to indicate that compatibility to make it easy to find a display - known to work.
And a small side-note:
This is on the "Edit Mbed Enabled Features" page | This is on the Components "Filter" page |
Hint: It is missing OS 5.11 | Hint: it is missing OS 5.10 and 5.11 |
But alas, all I get is "Unauthorized" if I click on them.
Could you enable access to this, or alternately clarify the intent?
thanks!
thanks!
