it is good to see that the CAN bus support is now included in mbed for STM32 and is seems to be working fine (on an STM32F303K8).
However, trying to set a reception filter did not work as I expected, so I changed the can_filter function in can_api.c to make it work for me.
Cheers,
Max
Changes to can_api.c
int can_filter(can_t *obj, uint32_t id, uint32_t mask, CANFormat format, int32_t handle) { CanHandle.Instance = (CAN_TypeDef *)(obj->can); CAN_FilterConfTypeDef sFilterConfig; sFilterConfig.FilterNumber = handle; sFilterConfig.FilterMode = CAN_FILTERMODE_IDMASK; sFilterConfig.FilterScale = CAN_FILTERSCALE_32BIT; sFilterConfig.FilterFIFOAssignment = 0; sFilterConfig.FilterActivation = ENABLE; sFilterConfig.BankNumber = 14 + handle; switch (format) { case CANStandard: sFilterConfig.FilterIdHigh = (uint16_t) (id << 5); sFilterConfig.FilterIdLow = 0; sFilterConfig.FilterMaskIdHigh = (uint16_t) (mask << 5); sFilterConfig.FilterMaskIdLow = CAN_ID_EXT; break; case CANExtended: sFilterConfig.FilterIdLow = (uint16_t) (id << 3); sFilterConfig.FilterIdLow |= CAN_ID_EXT; sFilterConfig.FilterIdHigh = (uint16_t) (id >> 13); sFilterConfig.FilterMaskIdLow = (uint16_t) (mask << 3); sFilterConfig.FilterMaskIdLow |= CAN_ID_EXT; sFilterConfig.FilterMaskIdHigh = (uint16_t) (mask >> 13); break; } HAL_CAN_ConfigFilter(&CanHandle, &sFilterConfig); return 0; }
