FRDM K64- USB host No interrupts
02 Mar 2016
I used the USB host library from Norimasa Okamoto ( https://developer.mbed.org/users/va009039/code/F401RE-USBHost/) for my FRDM K64 board and then a simple app to test the MSD.
When I insert the USB stick into the OTG port, I do not get any interrupts and no interrupt function is called. I tried with USB keyboard,but the same result.
I keep getting "Please attach USB device". Never the interrupt function got called USBHALHost::UsbIrqhandler();
used the same code as in the example(main.cpp of F401RE-USBHostMSD_HelloWorld) as below
main.cpp snippet
#include "USBHostMSD.h"
DigitalOut led1(LED_GREEN);
    USBHostMSD msd("usb");
    if (!msd.connect()) {
        error("USB Flash drive not found.\n");
    FILE* fp = fopen("/usb/test1.txt", "a");
    if (fp) {
        fprintf(fp, "Hello from mbed.\n");
        for(int i = 0; i < 21; i++) {
            fprintf(fp, " %d", i);
            led1 = !led1;
        fprintf(fp, "\n");
        fclose(fp);
    fp = fopen("/usb/test1.txt", "r");
    if (fp) {
        int n = 0;
            int c = fgetc(fp);
            if (c == EOF) {
                break;
            printf("%c", c);
            n++;
            led1 = !led1;
        fclose(fp);
        printf("%d bytes\n", n);
        led1 = !led1;
        wait_ms(200);
Also for FRDM K64 the initialisation code also contains MPU->CESR=0;
Why did not this work. Any clues or suggestions?
-yk
