Let's say you make a change by typing something in the editor. The save button gets highlighted and you can save it. However, if you undo that change, the save button is not highlighted and the editor does not consider the undo as a file modification. This means you can't save the file again, until you force a change by typing something in again (which messes up the redo history).
It would be nice if undo was given the same privilege to save a file as typing something in.
Zainul.
