I get this error anytime I try to use the 4DGL library...  Updated the firmware on the mbed, updated the mbed library, updated the 4DGL library... Using the simplest config possible.....
The program compiles with no errors...
The error message appears on putty which I am using as a serial terminal on the pc...
Any other program I try that uses the same mbed library on the same mbed, connected the same way, etc... works fine...no errors while trying to communicate...The error appears on the terminal, the program halts and nothing else happens...no doubling blinking leds, no nothing...halt...  hit reset, the error appears again and it halts...
Am I totally missing something obvious?  I'd really like to get past this and use the library... =)
(I put this under bugs/suggestions due to the fact that the error mentions the file serial_api.c line 115......which sounds to me like it's talking about the mbed side...??
I get this error anytime I try to use the 4DGL library... Updated the firmware on the mbed, updated the mbed library, updated the 4DGL library... Using the simplest config possible..... The program compiles with no errors...
