Hi Simon.
Yes, its working fine now.
And I have a small ( different problem )
This is the code I use:
if((c == 's')) // Stop Motor
if ( INa == !INa ){
INa = INa ;
pc.printf("Motor Stoped! \n");
else{
INa = !INa ;
pc.printf("Motor Started! \n");
pc.printf("PWM Speed = %1.2f\n",PWMSpeed);
And this is what I get in the terminal window:
Motor Started!
PWM Speed = 0.10
Motor Started!
PWM Speed = 0.10
Motor Started!
PWM Speed = 0.10
Motor Started!
PWM Speed = 0.10
The code goes into the different functions printf, comes out only from the else.
Is there a problem with the compiler?
and yes, there is a small glitch in the compiler.
Highlight a variable and cut it (Ctrl + X ).
Compile. Doesn't compile
Then Ctrl + Z. Lines comes back.
Compile. Doesn't compile, as if the code didn't come back.
Thanks.
Gidi.
Hi.
I have 2 mbed boards. With one I'm using the Serial pc(USBTX, USBRX); and it works fine. I'm getting a port# and I can connect to it using the Terminal.
I then tried to use the same software on a different board, and nothing. I can see that the software is running, but I don't get the CDC port in the windows. Nothing else is changing. same cable, same connection, same PC port, everything the same
I then tried a third board, also the same thing. Only on one I can see the CDC, on the rest, the software is running but the CDC is not opening.
Any idea?
Thanks.
