Hi Greg, I use the code below and think a modified version of this should work for you.
Whatever settings you make on the _RD, _WR pin in _init() should be retained. Use member functions to access the protected (pins) _RD or _WR.
(Sorry about the ugly layout, no idea why i get this when pasting code...)
BusEnums.h:
/* BusEnums - Use the MBED Port pins for controlling the Bus
- ifndef _BUS_ENUMS_H
- define _BUS_ENUMS_H
Enums for Control Bus and Enable Bus
enum Bit_Level { LOW, HIGH };
- endif
MBED_ControlBus.h:
- ifndef _MBED_CONTROLBUS_H
- define _MBED_CONTROLBUS_H
- include "BusEnums.h"
/ Create an MBED_ControlBus object connected to the specified Pins
- @param PinName WR the Write pin
- @param PinName RD the Read pin
class MBED_ControlBus {
public:
    MBED_ControlBus(PinName WR, PinName RD);
    void WR (Bit_Level wr_level);
    void RD (Bit_Level rd_level);
protected:
    DigitalOut _WR;     Write pin
    DigitalOut _RD;     Read pin
    void _init();
- endif
MBED_ControlBus.cpp:
/* MBED_ControlBus - Use MBED Port Pins for controlling the external Bus
- include "mbed.h"
- include "MBED_ControlBus.h"
MBED_ControlBus::MBED_ControlBus(PinName WR, PinName RD) :
   _WR(WR),         WR pin
   _RD(RD) {        RD pin
   _init();
/ Set or Clear the WR pin on Control Bus
- @param Bit_Level wr_level
void MBED_ControlBus::WR (Bit_Level wr_level) {
    if (wr_level == LOW) {
        _RD = 1;                     RD Pin High, make sure there is no collision
        _WR = 0;                     WR Pin Low
    else {
        _WR = 1;                     WR Pin High
/ Set or Clear the RD pin on Control Bus
- @param Bit_Level rd_level
void MBED_ControlBus::RD (Bit_Level rd_level) {
    if (rd_level == LOW) {
        _WR = 1;                     WR Pin High, make sure there is no collision
        _RD = 0;                     RD Pin Low
    else {
/ Init MBED_ControlBus
void MBED_ControlBus::_init() {
     Make sure that all Control pins are disabled
main.cpp:
MBED_ControlBus  controlbus = MBED_ControlBus(p23, p24);
  controlbus.RD(LOW);
  wait(1);
  controlbus.RD(HIGH);
I was trying to put all the pin declaration in one header file, so the source files just need to include it. However, it turns out if I include more than once of that header file, the compiler is complaining that I declare the pin more than once. Some thing like "Multiple pin declaration found in ??.cpp and ???.cpp". Then I try divided the pin declaration to specific source files, it works. But that would mean I can use only that certain pin in that certain source file, since header file method doesn't work, and I can declare it twice( compiler wouldn't let me). It is quite painful, when come to bebugging using USBTX and USBRX to print, and a lot other inconvinence. I hope you guys can make the header file method work, since I am really just declaring it once, and include it in other files...
Mahalo
Let me know how it goes ;)
