Where is itoa() ?
24 May 2011
Am I missing something here but where's the itoa() function in the Mbed cloud compiler? I did try adding #include "stdlib.h" and #include <cstdlib> without luck.
DigitalOut myled(LED1);
    int i;
    char *s;
    char fmtbuf[32];
    i = 100;
    s = itoa(i, fmtbuf, 16);
    printf("i in hex is %s\n", s);
        myled = 1;
        wait(0.2);
        myled = 0;
        wait(0.2);
Compiler reports:
Identifier "itoa" is undefined (E20)
24 May 2011
Looks like it's non-standard and not included. Why not just use sprintf?
24 May 2011
Thanks Igor. Was hoping to use a more "streamlined" function as opposed to the "brick through your window" that the *printf() family gives you. It'll have to do! ;)
24 May 2011
Instead of using printf you can use your "personal" itoa() function. The code is slim and simple (here K&R2 code). But you are right. itoa in standard libraries is the more comfortable way.
/* itoa:  convert n to characters in s */
 void itoa(int n, char s[])
     int i, sign;
     if ((sign = n) < 0)  /* record sign */
         n = -n;          /* make n positive */
     i = 0;
     do {       /* generate digits in reverse order */
         s[i++] = n % 10 + '0';   /* get next digit */
     } while ((n /= 10) > 0);     /* delete it */
     if (sign < 0)
         s[i++] = '-';
     s[i] = '\0';
     reverse(s);
18 Sep 2012
Love the mbed
Like C
Hate strings in C.....
Hi, I'm also attempting itoa as presented above, but reverse() does not seem to be implemented! Any updates/help to this code?
Many thanks
18 Sep 2012
Kevin,
The contents of the file reverse.c (from the SmallC 2.2 support library) -
** reverse string in place
reverse(s) char *s; {
char *j;
int c;
  j = s + strlen(s) - 1;
  while(s < j) {
    c = *s;
    *s++ = *j;
    *j-- = c;
12 May 2016
When You want to use custom base, the code can be modified like this:
include the mbed library with this snippet
char getNumber(int n){
  if(n>9) {
    return n-10+'a';
  } else {
    return n+'0';
 void itoa(int n, char * s, int base_n)
     int i, sign;
     i = 0;
         s[i++] = getNumber(n % base_n);   /* get next digit */
     } while ((n /= base_n) > 0);     /* delete it */
     if (sign < 0)
         s[i++] = '-';
     s[i] = '\0';
     reverse(s);
