12 years, 11 months ago.
In debugging with uVision, the current line stops automatically.
Hi, I am happy It is possible to debug mbed program.
I debugged this code with CMSIS-DAP in uVision. I started debugging, the current line stops automatically in fopen. I couldn't click both run button and step buttons, so I couldn't continue debugging.
debugging code
Serial uart(USBTX, USBRX);                  //USB uartSerialSerial uart(USBTX, USBRX);
DigitalOut myled(LED1);
// ***** local file read *****
bool usbFileRead(char *srcStr, char *readVal);// return 1:mormal, 0:error
LocalFileSystem local("local");             //local file system
short STR_SIZE = 64;
    char buffer[STR_SIZE];
    if(usbFileRead((char*)"TEST", buffer))
        uart.printf("true");
    else
        uart.printf("false");
        myled = 1;
        wait(0.2);
        myled = 0;
        wait(0.2);
short BUFFER_SIZE = 64;
bool usbFileRead(char *srcStr, char *readVal)  // return true:normal, false:error
    char readBuf[BUFFER_SIZE];
    FILE* fp = fopen("/local/config.txt","r");
        char *p;
    while(fgets(readBuf, BUFFER_SIZE, fp)) {
        if(*strstr(readBuf, srcStr))                // find srcStr from readBuf
        {                                                   //find srcStr
            p = fgets(readBuf, BUFFER_SIZE, fp);
            strcpy(readVal, p);
            fclose(fp);
            return true;
    fclose(fp);
    return false;
This program runs well in mbed. What should I do to continue debugging?
Thanks,
