6 years, 3 months ago.
Drawing a triangle
I need to draw a triangle, i found in the stm32746g_discovery_lcd.h
stm32746g_discovery_lcd.h line 227
 BSP_LCD_DrawPolygon(pPoint Points, uint16_t PointCount);
and i have no idea how i would set that up, i found in the stm32746g_discovery_lcd.c file where it references and the code is as follows.
stm32746g_discovery_lcd.c line 956
void BSP_LCD_DrawPolygon(pPoint Points, uint16_t PointCount)
  int16_t x = 0, y = 0;
  if(PointCount < 2)
    return;
  BSP_LCD_DrawLine(Points->X, Points->Y, (Points+PointCount-1)->X, (Points+PointCount-1)->Y);
  while(--PointCount)
    x = Points->X;
    y = Points->Y;
    Points++;
    BSP_LCD_DrawLine(x, y, Points->X, Points->Y);
I remember learning about the arrow operators and how they typically reference unions or arrays or something like that but i can't for the life of me remember exactly how to create what it needs. (and embarrassingly enough i remember this being the primary subject for nearly 3 days of classes)
Would someone please mind explaining this to me? or in the very least set up a simple 3 point triangle of some random coordinates for me to use as a reference? Thank you!
PS: BSP_LCD_FillPolygon would also work, but appears similar
The STM32F746G-DISCO discovery board (32F746GDISCOVERY) is a complete demonstration and development platform for STMicroelectronics ARM® Cortex®-M7 core-based STM32F746NGH6 microcontroller.
Hi there,
you need to follow the comments above the function
Quote:
  • @brief Draws an poly-line (between many points).
  • @param Points: Pointer to the points array
  • @param PointCount: Number of points
  • @retval None
So you need an array of coordinates and when you will look into parameters of the BSP_LCD_DrawPolygon(point Points, uint16_t PointCount); a struct of Point must exist.
One struct of stm32746g_discovery_lcd.c
typedef struct
  int16_t X;
  int16_t Y;
}Point, * pPoint;
So you need to add something like this, for example.
        Point p[3]; // tringle = 3 points = 3x struct of coordinates
        p[0].X = 240;   p[0].Y = 20;
        p[1].X = 200;   p[1].Y = 100;
        p[2].X = 280;   p[2].Y = 100;
        BSP_LCD_SetTextColor(LCD_COLOR_RED);
        BSP_LCD_DrawPolygon(p, 3);
You can simple copy & paste it into ST example, between lines 32-33.
Import programDISCO-F746NG_LCD_demo
Basic example showing how to drive the LCD.
BR, Jan
