6 years, 5 months ago.
Over the Air Firmware suggestions (Hardware suggestions)
We are developing a product and are stuck at Firmware over the air updates.
It seems like we will need a system that meets the following requirements:
  • From a firmware perspective, the platform should support delta updates so the entire firmware package doesn't have to be sent OTA, just the changes.
  • 32k ram minimum.
  • Ideally comes with an MPU.
  • Also ideally comes with some sort of cryptoprocessor/engine or crypto hardware acceleration - this is a nice to have but certainly not essential. Note: the last two are for security purposes only.
Do these requirements make sense to you? Would love to know if I'm missing anything critical.
I had some questions about how to handle the increased flash memory storage needs:
  • Should we go with a microcontroller having 512KB (512K x 8) or
  • Go with a uC having lesser memory and add an external flash memory
  • Also which of the above options are better in terms of firmware and other development and or best used in the development?
  • What else is required for FUOTA that we are forgetting?
Thanks for the help! Really appreciate the guidance.
For the smaller code size and if u don't need RTOS, add following line to mbed_app.json file
"requires": ["bare-metal"]
posted by Kamil M 01 Nov 2019
Hi Amir,
ARM Pelion Client supports both internal (RAM) flash and external flash and has delta update.
I would start testing by selecting test board from: https://os.mbed.com/platforms/ and then continue to https://www.pelion.com/docs/ You will find instruction how to connect the device to Pelion and how to do firmware update.
Regards, Pekka
6 years, 4 months ago.
What is your connection. If u are transmitting and receiving data over sub-ghz (RF), forget everything. Code your own firmware update algorithm.
