6 years, 6 months ago.
USBDEVICE support removed from NUCLEO_L4R5ZI in master branch
It seems USBDEVICE support was removed from the device I'm working on, NUCLEO_L4R5ZI. Was this intentional? I use this feature in my code.
The PR that removed it: https://github.com/ARMmbed/mbed-os/pull/11072
Thanks
Hi Daniel,
As you can see from PR https://github.com/ARMmbed/mbed-os/pull/11402 by Jerome, it was returned. Thank you for reporting this!
Mbed Support
Ron
Assigned to 6 years, 6 months ago.
We are checking now with ST if this was an intention or not.
posted by Martin Kojtal 03 Sep 2019Hi This is solved now Regards Jerome
posted by Jerome Coutant 12 Sep 2019
