6 years, 7 months ago.
Why isn't the patch number updated?
I have tried to synchronize my offline mbed-os library with the one used by the online compiler = Mbed OS 5.13.3, revision 808c45062f94:
A:\src\arm\mbed\mbed-os>mbed update 808c45062f94
[mbed] Working path "A:\src\arm\mbed\mbed-os" (program)
[mbed] Updating program "mbed-os" to rev #808c45062f94 (tags: latest, mbed-os-5.13.3)
However, the patch number in the mbed_version.h file wasn't updated correctly:
/* mbed Microcontroller Library
 * Copyright (c) 2018 ARM Limited
 * SPDX-License-Identifier: Apache-2.0
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
#ifndef MBED_VERSION_H
#define MBED_VERSION_H
/** MBED_MAJOR_VERSION
  * Mbed OS major version
  * @note 99 is default value for development version (master branch)
#define MBED_MAJOR_VERSION 5
/** MBED_MINOR_VERSION
  * Mbed OS minor version
#define MBED_MINOR_VERSION 13
/** MBED_PATCH_VERSION
  * Mbed OS patch version
#define MBED_PATCH_VERSION 2
#define MBED_ENCODE_VERSION(major, minor, patch) ((major)*10000 + (minor)*100 + (patch))
/** MBED_VERSION
  * Mbed OS 5 version (MMmmpp - M(Major); m(minor); p(patch))
  * @note 999999 is default value for development version (master branch)
#define MBED_VERSION MBED_ENCODE_VERSION(MBED_MAJOR_VERSION, MBED_MINOR_VERSION, MBED_PATCH_VERSION)
/** MBED_VERSION_CHECK
  * Macro can be used to check minimum Mbed OS version required for feature/library. If current version
  * is less than required, it will assert.
  * @note: Version of master branch will be 999999 as default, hence no assert/warning is provided for
  * master branch code
#define MBED_VERSION_CHECK(major, minor, patch) do { \
                                       MBED_STATIC_ASSERT((MBED_VERSION >= MBED_ENCODE_VERSION((major),(minor),(patch))), "Incompatible mbed-os version detected!!"); \
                                     } while(0)
#endif
Is it because this issue hasn't been fixed yet?
Hi, just a follow-up, Mbed OS 5.13.4 is released, and I think the revision is updated correctly.
posted by Desmond Chen 29 Aug 2019
Hi Zoltan,
Thank you for reporting this, we are aware of this mistake and already make it announced in our release page. https://os.mbed.com/mbed-os/releases/
Regards, Desmond
Yes, it works. Thank you!
posted by Zoltan Hudak 31 Aug 2019
