6 years, 9 months ago.
How to correct TCPServer and accept is depreciated
Mbed-OS-example gives depreciated warning on 'TCPServer' and 'accept' (lines 15 and 29)
https://os.mbed.com/teams/mbed_example/code/mbed-os-example-tcp-server/file/ddb5698aa782/main.cpp/
#include "TCPServer.h"
#include "TCPSocket.h"
printf("TCP server example\n");
EthernetInterface eth;
eth.connect();
printf("The Server IP address is '%s'\n", eth.get_ip_address());
TCPServer srv;
TCPSocket client_sock;
SocketAddress client_addr;
char *buffer = new char[256];
/* Open the server on ethernet stack */
srv.open(ð);
/* Bind the HTTP port (TCP 80) to the server */
srv.bind(eth.get_ip_address(), 23);
/* Can handle x simultaneous connections */
srv.listen(1);
srv.accept(&client_sock, &client_addr);
printf("Accepted %s:%d\n", client_addr.get_ip_address(),
client_addr.get_port());
strcpy(buffer, "Hello \n\r");
client_sock.send(buffer, strlen(buffer));
client_sock.recv(buffer, 256);
client_sock.close();
delete[] buffer;
Although it does still work atm, I would like to use the correct code, can someone give me an example to to do this?
Even better could the example be updated on Mbed.
Hi Paul,
About the TCPServer I wrote in the comments under my answer in last question about TCP https://os.mbed.com/questions/86423/mbed-os-tcp-server-example-with-Nucleo-F/, where you wrote too.
TCPServer
//#include "TCPServer.h" // not needed anymore
//#include "TCPSocket.h" // not needed anymore
eth.connect();
//TCPServer srv; //TCPServer was migrate to TCPSocket
TCPSocket srv;
TCPSocket *client_sock; // srv.accept() will return pointer to socket
srv.open(ð);
srv.listen(1);
client_sock = srv.accept(); //return pointer of a client socket
client_sock->getpeername(&client_addr); //this will fill address of client to the SocketAddress object
printf("Accepted %s:%d\n", client_addr.get_ip_address(), client_addr.get_port());
client_sock->send(buffer, strlen(buffer));
client_sock->recv(buffer, 256);
printf("Received Msg: %s\n", buffer); //this was missing in original example.
client_sock->close();
delete[] buffer;
Request about update of some example is better place it on github or email or pull request, maybe. However you are right, too many examples are out of date and a Mbed newbie or a beginner with an Api (I not say "You" :) ) can be confused when example and documentation say different things.
Best regards J.
