6 years, 9 months ago.
mbed support STM32F303RBT6?
can't see this chip info listed on mbed anywhere - was wondering if anyone has got it working/has a solution
thanks
Not an answer really but I have looked into this a bit and setting up a new target is very involved. It requires extensive knowledge of the target, of other ST targets in that family (because code is shared), and knowledge of pretty much all of mbed-os. Even if you worked all that out you have a maintenance problem going forward because your target is not being maintained by the mbed team. If you already have a PCB with that micro it is almost certainly less work to respin the board with an mbed compatible micro than to try to adapt mbed to your micro. IMHO. Would be curious if anyone disagrees.
