6 years, 10 months ago.
AnalogIn read within a Callback
I am trying to create a class that takes care of polling an analog in pin, and stores the results in an array. I am trying to do this with a ticker and callback. The idea is that the main loop can interrogate the data that has been collected in this class. If I use analogin.read in my callback I get a Mutex Lock error It works fine if I am using a digitalin.read What is the correct way for me to set up collecting sample readings from analogin outside the main loop?
In general do not put any code in an interrupt callback function or as little as possible.
In that callback function, simply set a flag and act on that flag in your main program.
I use something very basic like this to sense an operator switch input:
void callback() {
while(SW1==1); // wait for release of switch (this is blocking)
IRQ=1; // variable IRQ is set to 1, test for this in main program.
This example is not be thread based RTOS friendly.
