7 years ago.
[ERROR] armclang: error: System clock tampering detected. License checkout will fail.
Can't pass build, i'm using the bundled tools, i assume ARM compile 6 is included
More logs:
[ERROR] armclang: error: System clock tampering detected. License checkout will fail. armclang: error: Failed to check out a license. armclang: note: Information about this error is available at: http://ds.arm.com/support/lic56/m1004 General licensing information is available at: http://ds.arm.com/support/licensing/ If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: 'C:\MbedStudio\tools\ac6-license.dat' - LM_LICENSE_FILE: unset - ARM_TOOL_VARIANT: unset - ARM_PRODUCT_PATH: unset - Product location: C:\MbedStudio\tools\ac6\sw\mappings - Toolchain location: C:\MbedStudio\tools\ac6\bin - Selected tool variant: product armclang: note: - Checkout feature: mbed_armcompiler - Feature version: 5.0201810 - Flex error code: -1004 Product: ARM Compiler 6.11 for Mbed Studio Component: ARM Compiler 6.11 Tool: armclang [5d3b3c00] armclang: error: ARM Compiler does not support '-mcpu=cortex-m0plus'
7 years ago.
Hi Neo,
You are correct - Arm Compiler 6 is bundled with Mbed Studio and it can be used without an external license (which is normally required). However, there is still a licensing check running and part of that check is to confirm that the host's system time hasn't been altered. Is your system time correct? If so, do you have any "future files" on your system (where the time/date stamp is ahead of system time)? If so, you'll need to remove these to satisfy the license check.
Ralph, Team Mbed
