7 years ago.
How can I display a text and the value of a variable on an LCD display?
I have a 16x2 LCD display, in one of the lines I want to show something like this:
"Sequence: 3"
Where sequence would be a text and 3 would be a variable that is entered by a DIP switch of three positions.
Thanks for your reply
7 years ago.
Start by selecting one of the available LCD software components here. For example, my library, allows you to use printf on the LCD:
#include "TextLCD.h"
// Host PC Communication channels
// I2C Communication
I2C i2c_lcd(p28,p27); // SDA, SCL
// SPI Communication
SPI spi_lcd(p5, NC, p7); // MOSI, MISO, SCLK
//TextLCD lcd(p15, p16, p17, p18, p19, p20); // RS, E, D4-D7, LCDType=LCD16x2, BL=NC, E2=NC, LCDTCtrl=HD44780
//TextLCD_I2C lcd(&i2c_lcd, 0x42, TextLCD::LCD20x4); // I2C bus, PCF8574 Slaveaddress, LCD Type
//TextLCD_I2C lcd(&i2c_lcd, 0x42, TextLCD::LCD16x2, TextLCD::WS0010); // I2C bus, PCF8574 addr, LCD Type, Ctrl Type
TextLCD_I2C lcd(&i2c_lcd, 0x42, TextLCD::LCD16x2); // I2C bus, PCF8574 addr, LCD Type, Ctrl Type
//TextLCD_I2C lcd(&spi_lcd, p8, TextLCD::LCD24x4D); // SPI bus, CS pin, LCD Type
int dip;
pc.printf("LCD Test. Columns=%d, Rows=%d\n\r", lcd.columns(), lcd.rows());
dip = 3; // read this from some DigitalIn pins
lcd.printf("Sequence: %d\n\r", dip);
It depends entirely on the LCD you are using. If you can display text strings on it then you can use sprintf to create a string with the number in it.
Reading the switch value into a variable is just a case of adding numbers up.
Your code would end up as something like this
