7 years ago.
How to compile assembly language code offline with Mbed CLI?
The assembly language example compiles smoothly with online compiler. But when I'm trying to compile the same project imported to local drive with Mbed CLI it reports errors:
Compile [ 99.5%]: my_asm.s [ERROR] .\my_asm.s: Assembler messages: .\my_asm.s:1: Error: bad instruction `area asm_func,CODE,READONLY' .\my_asm.s:3: Error: bad instruction `export my_asm function location so that C compiler can find it and link' .\my_asm.s:6: Error: bad instruction `export my_asm' .\my_asm.s:7: Error: bad instruction `my_asm' .\my_asm.s:9: Error: bad instruction `arm Assembly language function to set LED1 bit to a value passed from C' .\my_asm.s:10: Error: bad instruction `led1 gets value(passed from C compiler in R0)' .\my_asm.s:11: Error: bad instruction `led1 is on GPIO port 1 bit 18' ...
How can I get it compiled offline with Mbed CLI?
7 years ago.
Dear Zoltan, there are two different assemblers, the ARM assembler for the online and Studio environment and the GNU assembler for the offline use. The syntax is different, therefore I write the assembler code twice and via an #ifdef I define which one to use. (PS: You can also generare assembler from C/C++ code via the -S compiler option)
Regards Helmut
Here is an example:
Assembler
#ifdef MBED_FAULT_HANDLER_DISABLED
#ifdef __ARMCC_VERSION
;********************** COPYRIGHT(c) 2017 HELIOS Software GmbH ****************
MACRO
$L CreateHandlerStub $Name
$Name._Handler PROC
push {r7,lr} ; +r7 to keep stack 8 bytes aligned
movs r2, #0x04
mov r1, lr
tst r1, r2
beq $L.l4
mrs r1, psp
b $L.l5
$L.l4 mrs r1, msp
movs r2, #0x08
add r1, r2
$L.l5 nop ; for reasons unknown, the online assembler fails
adr r0, $L.name ; without this nop
bl FaultError
$L.name dcb "$Name",0
ALIGN
ENDP
EXPORT $Name._Handler
MEND
AREA ||.text||, CODE, READONLY, CODEALIGN
IMPORT FaultError
PRESERVE8
NMI_Handler CreateHandlerStub NMI
HardFault_Handler CreateHandlerStub HardFault
MemManage_Handler CreateHandlerStub MemManage
BusFault_Handler CreateHandlerStub BusFault
UsageFault_Handler CreateHandlerStub UsageFault
GenerateFault PROC
movs r0,#0
subs r0,#3
movs r1,#1
movs r2,#2
movs r3,#3
ldr r0,[r0, #0]
ENDP
EXPORT GenerateFault
PRESERVE8
END
#elif defined(__GNUC__)
@ We define each fault handler to be a function of its own to have proper stack backtraces
.macro CreateHandlerStub Name,NameId
.align
.global \Name\()_Handler
.thumb_func
.type \Name\()_Handler, %function
\Name\()_Handler:
push {r7,lr} @ +r7 to keep stack 8 bytes aligned
movs r2, #0x04
mov r1, lr
tst r1, r2
beq 4f
mrs r1, psp
b 5f
4: mrs r1, msp
movs r2, #0x08
add r1, r2
5:
nop
adr r0, 6f
bl FaultError
6: .asciz "\Name"
.align
.size \Name\()_Handler, . - \Name\()_Handler
.endm
.section .text
.thumb
.syntax unified
#endif
#endif
