7 years, 2 months ago.
Mbed OS 2 release 165 causes hard fault on K64F
Since the 165 release, it has not been possible to get code to run on a K64F using Mbed OS 2 (on both K64F's with latest DAPlink firmware and also brand-new K64F's fresh out of the box).
Even a simple GPIO blinky example fails the run and the following fault message appears in the terminal:
-- MbedOS Fault Handler -- ++ MbedOS Error Info ++ Error Status: 0x80FF013D Code: 317 Module: 255 Error Message: Fault exception Location: 0x493F Error Value: 0xE7E For more info, visit: https://armmbed.github.io/mbedos-error/?error=0x80FF013D -- MbedOS Error Info -- = System will be rebooted due to a fatal error = = Reboot count(=35) reached maximum, system will halt after rebooting ++ MbedOS Fault Handler ++ FaultType: HardFault Context: R0 : 00006A74 R1 : 00000000 R2 : 00007A74 R3 : 200000E4 R4 : 00007A74 R5 : 00006A74 R6 : 00006A84 R7 : 20000548 R8 : 00000000 R9 : 00000000 R10 : 0000685C R11 : 0000685C R12 : 00000000 SP : 2002FFD0 LR : 00000E67 PC : 00000E7E xPSR : 41000000 PSP : 00000000 MSP : 2002FF68 CPUID: 410FC241 HFSR : 40000000 MMFSR: 00000000 BFSR : 00000086 UFSR : 00000000 DFSR : 00000008 AFSR : 00000000 BFAR : 00006A74 Mode : Thread Priv : Privileged Stack: MSP
Switching back to version 164 fixes the issue.
7 years, 1 month ago.
Hi Craig,
Thank you for reporting this problem. We've just confirmed that a program never reaches main() so we suspect there is a problem with changes made to the scatterfile. This only impacts Mbed OS2 so we created an internal tracking JIRA. We'll update you as soon as a fix is available. Please continue using version 164.
Our apologies for the inconvenience.
Ralph, Team Mbed
