7 years, 1 month ago.
max30001 compile
/media/uploads/soooooooin/error.png
I used MAX30001EVkit. I want measure the bioZ value using PC with EVkit. Is there any code provided by Mbed? I do not want to use the SW provided by the MAXIM. I want to manipulate the kit directly with the code.
Once I found the ECG measurement code in mbed (MAX30001-MAX32630FTHR-ECG-EVKIT) it does not work properly in a terminal window. Can you tell me why?
That looks like your Serial Baud rates are not matched. Mbed default is 9600, check Tera Term rate is 9600.
Serial Baud rate are matched but the state is the same.
posted by sooin huh 04 Mar 2019
