7 years, 1 month ago.
mbed serial - print variable value
Board: FRM K64f
Trying to print a value of a variable.
heres code
Serial pc(USBTX, USBRX); int main () {
DynamixelClass my(57600, PTC17, PTC16);
int pos = my.readPosition(SERVO_ID);
pc.baud(57600);
pc.printf("H");
pc.printf(pos);
Error: Argument of type "int" is incompatible with parameter of type "const char *" in "main.cpp", Line: 12, Col: 16
correct is...
pc.printf("%d \n", pos);
http://www.cplusplus.com/reference/cstdio/printf/
okay, that seems to have worked partially, now it doesnt even print H which appears before the correction
posted by Bilal Saleem 24 Feb 2019
It will be printing the H but on the same line as the number with no spaces between them. If you want a new line you need to include either \n or \r\n, (unix or DOS line endings, most terminals have an option to select which on to expect.)
posted by Andy A 25 Feb 2019
