7 years, 2 months ago.
How do I specify the Tx/Rx pins for any given board
In my case I want to connect this board
https://os.mbed.com/platforms/MAX32630FTHR/
to the ESP8266 and run the example.
Where do I specify the Tx and Rx pins ?
Edit...
I did see the README.md file but it's not that clear and I'm not sure if it can be done.
Perhaps someone could clarify please, ideally with an example.
Hello Paul,
That's a very good question. The mbed-os-example-wifi just briefly says that "ESP8266 is a fallback option and will be used if the build is for unsupported platform".
Searching the Mbed OS 5.11 source code then reveals that:
esp8266Interface.h
//.. #ifdef TARGET_FF_ARDUINO #ifndef MBED_CONF_ESP8266_TX #define MBED_CONF_ESP8266_TX D1 #endif #ifndef MBED_CONF_ESP8266_RX #define MBED_CONF_ESP8266_RX D0 #endif #endif /* TARGET_FF_ARDUINO */ //..
esp8266Interface.cpp
#if defined MBED_CONF_ESP8266_TX && defined MBED_CONF_ESP8266_RX
ESP8266Interface::ESP8266Interface()
: _esp(MBED_CONF_ESP8266_TX, MBED_CONF_ESP8266_RX, MBED_CONF_ESP8266_DEBUG, MBED_CONF_ESP8266_RTS, MBED_CONF_ESP8266_CTS),
_rst_pin(MBED_CONF_ESP8266_RST), // Notice that Pin7 CH_EN cannot be left floating if used as reset
_ap_sec(NSAPI_SECURITY_UNKNOWN),
_if_blocking(true),
_if_connected(_cmutex),
_initialized(false),
_conn_stat(NSAPI_STATUS_DISCONNECTED),
_conn_stat_cb(NULL),
_global_event_queue(NULL),
_oob_event_id(0),
_connect_event_id(0)
memset(_cbs, 0, sizeof(_cbs));
memset(ap_ssid, 0, sizeof(ap_ssid));
memset(ap_pass, 0, sizeof(ap_pass));
_esp.sigio(this, &ESP8266Interface::event);
_esp.set_timeout();
_esp.attach(this, &ESP8266Interface::update_conn_state_cb);
for (int i = 0; i < ESP8266_SOCKET_COUNT; i++) {
_sock_i[i].open = false;
_sock_i[i].sport = 0;
_oob2global_event_queue();
#endif
From that I concluded that for Mbed boards equipped with Arduino headers the ESP8266 TX pin is specified as D1 and ESP8622 RX pin as D0.
To specify TX and RX for unsupported Mbed boards the mbed_app.json file could look like:
mbed_app.json
"config": {
"wifi-ssid": {
"help": "WiFi SSID",
"value": "\"SSID\""
"wifi-password": {
"help": "WiFi Password",
"value": "\"PASSWORD\""
"target_overrides": {
"target.network-default-interface-type": "WIFI",
"esp8266.tx": "p9",
"esp8266.rx": "p10",
"esp8266.socket-bufsize": "1024",
"platform.stdio-convert-newlines": true
NOTE: Replace p9, p10 with actual TX, RX pin names of used Serial port, respectively.
Hello Zoltan,
Thank you for your time investigating, however unfortunately I get:
WiFi example Mbed OS version 5.11.4
ERROR: No WiFiInterface found.
I did also try 3 of the default boards and got the same result so that's it for now, maybe the next revision it will be working again.
For now I will continue with Mbed 2 as that's working well atm.
posted by 20 Feb 2019I've added one more line to the mbed_app.json file to set the esp8266.socket-bufsize.
Then after making this modification to the main.cpp it works fine for me with LPC1768 :)
main.cpp
#include "ESP8266Interface.h"
//WiFiInterface *wifi;
ESP8266Interface *wifi;
//wifi = WiFiInterface::get_default_instance();
wifi = new ESP8266Interface();
