7 years, 1 month ago.
Serial Attach issue with OS5xx
Using OS5 rev.5349
When I do this;
esp2.attach(&espReceive,Serial::RxIrq);
I get this on my terminal:
++ MbedOS Error Info ++
Error Status: 0x80020115 Code: 277 Module: 2
Error Message: Mutex lock failed
Error Value: 0xFFFFFFFA
Current Thread: main Id: 0x200035A8 Entry: 0x8C6B StackSize: 0x1000 StackMem: 0x200025A8 SP: 0x2007FF58
For more info, visit: https://armmbed.github.io/mbedos-error/?error=0x80020115
MbedOS Error Info
Why?
Works fine with OS2, but I'm struggling to get any of my work running on OS5
The Serial information here is not much help either, at least not for me.
https://os.mbed.com/docs/mbed-os/v5.11/apis/serial.html
I'm sure there's a simple answer, can anyone point me in the right direction.
Thank you
Paul.
Hello Paul,
In the current version of Mbed OS 5, if you attempt to use a mutex from within an ISR, it will treat that as a fatal system error. So the reported error most likely results from calling the lock function in the attached ISR rather than from attaching a function to the 'serial received' interrupt. Because Serial is derived from SerialBase, Stream and NonCopyable and functions like readable, getc, read etc. (inherited from those classes) usually call the lock as their first action, you are not allowed to use them within an ISR anymore.
- One solution is to define a global
volatileflag, let ISR to set that flag when handling the interrupt and take action in themainfunction by testing the flag. - Another solution is to defer execution of non-ISR safe functions, like
readable,getcetc., by using EventQueue.
Hmmm, not the 'simple' answer I was hoping for.
I really don't want this thread system for my work atm, although it does look interesting and will play with it when I get time.
Is there any command I can use that will completely disable all of the OS5 features so that it runs like OS2? Something like "#define os2" at the top of 'main' would be good.
posted by 15 Feb 2019As usual there are some pros and some cons as the OS grows. It's very difficult to meet all the requirements and support so many various targets. This is what I was able to find that could be of help: https://os.mbed.com/forum/blog-Reducing-memory-usage-by-tuning-RTOS-con-404-forum/topic/28622/
