7 years, 1 month ago.
about Mbed 1768
hello all
i want to know maximum frequency of Mbed 1768 by I2C.
thanks
Specs are given in bits/sec.
check page 32 of the LPC1768 data sheet:
https://www.nxp.com/docs/en/data-sheet/LPC1769_68_67_66_65_64_63.pdf
400 kbit/s is the standard (fast) nowadays (check the device data sheet, old ones are 100kbit/s) and can run up to 1 Mbit/s. but that depends on the i2c device itself and device to MCU distance . I think I saw a 3.4Mbit/s (high speed mode) somewhere, but never used one.
Depending on the message length you are looking at around 50% - 90% data/frequency ratio to account for start/stop etc. overheads, the longer the message the less overheads.
Generally, set the i2c frequency to the same as the bit/s indicated on the device.
I think the highspeed I2C engine is not available on the LPC1768 mbed because the SDA/SCL pins are not accessible on the external header. Best you can get is probably 400kb
