7 years, 1 month ago.
HelloWorld for two stacked IHM02A1 boards
Hello ST-Team, I really enjoy your work at the hole STM32 Nucleo project. I now woud like to use two IHM02A1 expansion board stacked on the NUCLEO-F302R8.
I modified your HelloWorld_IHM02A1 for the second expansion board. But I still can use one board at the same time. In the example I can change the order of the initializing of the expansion boards with the result that it chanche the working expansion board.
Can you please help my with a correction of my code or another HelloWorld example with multiple IHM02A1 boards?
Yours faithfully, Sven Brieden
minimal example: HelloWorld for two stacked IHM02A1
/* Includes ------------------------------------------------------------------*/
/* mbed specific header files. */
/* Helper header files. */
#include "DevSPI.h"
/* Expansion Board specific header files. */
#include "XNucleoIHM02A1.h"
DigitalIn User_Button(USER_BUTTON);
/* Definitions ---------------------------------------------------------------*/
/* Motor Control Expansion Board. */
XNucleoIHM02A1 *x_nucleo_ihm02a1_a;
XNucleoIHM02A1 *x_nucleo_ihm02a1_b;
/* Initialization parameters of the motors connected to the expansion board. */
L6470_init_t init[L6470DAISYCHAINSIZE] = {
    /* First Motor. */
        45.0,                           /* Motor supply voltage in V. */
        400,                           /* Min number of steps per revolution for the motor. */
        1.7,                           /* Max motor phase voltage in A. */
        3.06,                          /* Max motor phase voltage in V. */
        300.0,                         /* Motor initial speed [step/s]. */
        500.0,                         /* Motor acceleration [step/s^2] (comment for infinite acceleration mode). */
        500.0,                         /* Motor deceleration [step/s^2] (comment for infinite deceleration mode). */
        992.0,                         /* Motor maximum speed [step/s]. */
        0.0,                           /* Motor minimum speed [step/s]. */
        602.7,                         /* Motor full-step speed threshold [step/s]. */
        3.06,                          /* Holding kval [V]. */
        3.06,                          /* Constant speed kval [V]. */
        3.06,                          /* Acceleration starting kval [V]. */
        3.06,                          /* Deceleration starting kval [V]. */
        61.52,                         /* Intersect speed for bemf compensation curve slope changing [step/s]. */
        392.1569e-6,                   /* Start slope [s/step]. */
        643.1372e-6,                   /* Acceleration final slope [s/step]. */
        643.1372e-6,                   /* Deceleration final slope [s/step]. */
        0,                             /* Thermal compensation factor (range [0, 15]). */
        3.06 * 1000 * 1.10,            /* Ocd threshold [ma] (range [375 ma, 6000 ma]). */
        3.06 * 1000 * 1.00,            /* Stall threshold [ma] (range [31.25 ma, 4000 ma]). */
        StepperMotor::STEP_MODE_1_128, /* Step mode selection. */
        0xFF,                          /* Alarm conditions enable. */
        0x2E88                         /* Ic configuration. */
    /* Second Motor. */
/* Main ----------------------------------------------------------------------*/
    /* Initializing Motor Control Expansion Board. */
    if(User_Button==1)
    {   /* If I press the button only x_nucleo_ihm02a1_a is working */
        x_nucleo_ihm02a1_a = new XNucleoIHM02A1(&init[0], &init[1], A4, A5, D4, A2, D11, D12, D13);
        x_nucleo_ihm02a1_b = new XNucleoIHM02A1(&init[0], &init[1], A4, A5, D4, D10, D11, D12, D13);
    else
    {   /* In this case only x_nucleo_ihm02a1_b  works*/
    /* Building a list of motor control components. */
    L6470 **motors_a = x_nucleo_ihm02a1_a->get_components();
    L6470 **motors_b = x_nucleo_ihm02a1_b->get_components();
    /* Moving Motors */
    printf("Moving  motors from Board 1 \r\n");
    motors_a[0]->move(StepperMotor::FWD, 20 * 128);
    motors_a[1]->move(StepperMotor::FWD, 20 * 128);
    wait_ms(2000);
    printf("Moving  motors from Board 2 \r\n");
    motors_b[0]->move(StepperMotor::FWD, 20 * 128);
    motors_b[1]->move(StepperMotor::FWD, 20 * 128);
ST
A world leader in providing the semiconductor solutions that make a positive contribution to people’s lives, both today and in the future.
6 years, 11 months ago.
Hi Sven and ST-Team,
I have the same problem with the NUCLEOF401RE. x_nucleo_ihm02a1_2 = new XNucleoIHM02A1(&init[0], &init[1],A4, A5, D4, A2, D11, D12, D3 ); x_nucleo_ihm02a1_1 = new XNucleoIHM02A1(&init[0], &init[1], A4, A5, D4, D2, D11, D12, D3 ); The nCS pins are soldered correctly on SB23 and SB7
I'd appreciate it very much if you could help
Yours faithfully, Fabian Scherrer
