7 years, 3 months ago.
Saving files on the server makes the file of length zero. Unable to compile
Again it is impossible to compile a project with the online compiler. Save and save all results in zero file size on the server. Result a bunch of errors of coarse.
This is the third time I found this problem.
Regards, Jacques Paul
If you have lost a file during this incident please email support@mbed.com stating that you were affected by the ide.mbed.com incident. Also state the name of the affected program and your os.mbed.com username. We will then arrange access to the most recent backup of your program, and you will be able to restore it.
Sorry for the inconvenience
Sam
Same here!
!! Beware it erases the contents completely !!
Copy the onscreen code and save as a text file on your local PC before saving just in case. You can always paste it back later.
Same here!! Somethings wrong in the server..
Not able to choose mbed build revisions. Compiler/server is not able to list the revisions.
Says "Loading Please wait...." & nothing happens
Problem is solved, you have to restore your onw code in the project. Then all seems to work fine again. Just mail to support@mbed.com with your project name and the project you want to be restored. They will help you
posted by Jacques Paul 21 Dec 2018
